90% decided on wheels
Now I have to ask about perfomance gain. I'm looking at the Rota Subzero's at 16x7 and I currently have X-lites. I checked wheelweights and the weight savings shows to be 3.1lbs per wheel. Stock shows 17.6lbs and Subzero's at 14.5lbs.
This is for a daily driver with quite a bit of spirited driving on the back roads. Also Dragon trips and Phil Wicks on occasion. I understand a reduction in wheel weight does help but how much it helps I have no idea about.
From what I understand, the Subzero's will stick out a little further than stock with a 40mm offset. What differences will I see by changing to Subzero's other than a different look? Speed or handling? I still plan to keep the same size tires. 205/50/16 ES100's.
I'm trying to justify changing the wheels. Being cheap has its drawbacks.
on
The lighter weight wheels will help your accelleration a little bit, but it won't be a huge change.
For really significant weight savings, you might want to consider some 15" wheels which can get down to about 11 pounds. . . tires will also be a little cheaper in a 15" size too. . . .
A nice 15x7 wheel is on my wish list, but like you I am cheap and have my eyes on some rather expensive wheels (not going to happen). . ..
ltjpunk7
09-06-2015 07:32 AM
ccccPUNISHER
08-20-2015 09:02 PM
