17 x 7.5 ET40 - ideal tire size?
on
Id like to go 215/45/17, but i fear the all to common rubbin'. That said, im handy with a dremel :-)
Im not overly concerned right now at stock height, but will likely be dropping it an inch or so in the not too distant future. Likely H-Sports.
What would the mighty NAM members say is the best best size wise.
17x7 ET40 running 205/45/17s with Eibachs.
I do get slight rubbing on the rear over firm-ish bumps or with a load up. It sounds a lot worse than it is, on close inspection with the tyre the area that is rubbing is very minimal. So much so, that I'm not concerned by it.
Mind, I'm currently running Michelin Pilot Precedas which have a very square sidewall design. My previous tyres were Goodyear Revspecs and the sidewall design was much rounder. Sounds odd I guess, but I think this difference would almost be enough to stop the rubbing. But seeing as I didn't have them on the car with the Eibachs I can't say for sure.
Originally Posted by mini pooper
For what it's worth, I am running Team Dynamic Pro Race 1 Racing Wheels 7.0 X 17 (Black) with Bridgestone Potenza S-03 Pole Position UNI-T AQ11 205/50ZR17 89V and I am getting rear tire rubbing
205/50/17 is kinda meaty too... and S03's come in huge widths much bigger
than their spec 205/50 is probably like 225-230mm width when you actually
measure it.
205/50/17 Tires
Wheels:
I will really have to check to verify the offset, but the offset range is e+35 to e+50 with a wheel weight of 7.3 Kg at max. offset.
The tires:
Diameter: 25.1
Overall sectional width: 8.4
tread width: 7.6
Static load radius: 11.6
tire wt: 24
They are pretty "beefy".
The tires:
Diameter: 25.1
tread width: 7.6
tire wt: 24
i tried 205/50-17 on 42mm offset just before winter started, and got too much rubbing, it literally rubbed at any bumps even with just me on board.. changing the camber to now 2.5 degrees helped a tiny bit, not enough though, so i was forced to trade with my friend's 215/45 setup with half its tread worn with crappier wheels for my newer wheels on brand new tires.... with no money back!
cant really see the back, but here is what it looked like
worse still......... rubbing is still there when i go over HUGE bumps with a rear passenger!
I just layed the sticker on the back for the photo. It's magnetic so it would normally go on the doors.
The ONLY sticker I have is my REME (Redwood Empire Mini Enthusiasts) which is blue and is placed right at the top of the rear window.
There was a thread about it not too long ago.
col127
08-21-2015 02:11 PM
Mini'mon
08-16-2015 04:15 PM
