15 vs. 16 in. R compound tires for the track
Originally Posted by JeffS
What's the actual question?
IMO, there's no reason to run 16's unless you already have the wheels.
![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
From experience, for non-competitive driving events, I think a Kumho V700 Victoracer is a great choice, in 205-50-15. I have never used the Toyo RA1, but I've heard it's more durable and not a whole lot slower than the Kumho, for what that's worth.
Originally Posted by scobib
I'm running 225/50R15 Michelin Pilot Sport Cups... 15 x 6.5 wheel with a +42 ET. No rubbing for me... Just be careful with the offset, otherwise, you'll be fine.
The difference in stick between 205's and 225's is quite a bit...
on
Originally Posted by kapps
scobib, do you think a +40 offset would rub the fender? Since your running +42 and not rubbing the strut or fender, all I'd have to worry about with +40 is the fender lining.
I don't think +38 would be an issue, either...
23.9" O.D. according to the manufacturer's specs... They are bigger donuts than stock, for sure! Originally, I was a bit worried about the bigger diameter - until I ran on them...
They look cool when on, though. And, they just stick like glue on our autocross lot's VERY rough surface. I full expect to get 9 events out of them, 8 runs per event. Besides the Toyo RA-1's, the PSC's are the ONLY R-compound that provide that kind of life on our surface... HooHoo's go about 3-4 events, as do V710's. They aren't as fast as the HooHoo's or V710's, BUT they're fast enough to beat the BMW's AND a better overall bang-for-the-considerable-buck.
![Grin](https://www.northamericanmotoring.com/forums/images/smilies/grin.gif)
![Nod](https://www.northamericanmotoring.com/forums/images/smilies/nod.gif)
Originally Posted by Madmax
...w 225/50 Victoracers. No rubbing issues. Tires handle awesome- but wear is not good. I've done 3 track days at Mosport - they might go one more. I am switching to Toyo and give them a try this season.
There's no holy grail, yet. The stickier the rubber, the shorter the lifespan. RA1s are great because they're a lot stickier than street tires but don't confuse them with race rubber. The other helpful thing about them is they don't harden & dry out with repeated heat cycles, unlike Hoosiers etc. The Spec Miata guys used to say that RA1s were best right before you corded them -- least tread squirm, no tread blocks really left, lowest weight, and still good and sticky.
A good driver will preserve his tires regardless of how sticky they are but the decision usually comes down to how competitive you want to be, rather than whether or not you've actually killed the tire. Unless your VictoRacers are corded, blistered, etc, I'd keep using them until they're truly dead.
twj
Very good point about wear being relative. When I did race I would go thru a set of slicks every race and get maybe a practice session with them next time out. I think most of us who are doing mostly track days can certainly get better wear with a little tire management and bring the car in within a reasonable number of laps to let the rubber cool down. With these types of tires it's all about number & the length of heat cycles that determine not just wear- but the performance over the life of the tire. Yes, the V700's are good to the last drop- but I have never ran the Toyo's- just thought I would give them a try.
squawSkiBum
Tires, Wheels, & Brakes
26
03-18-2024 07:21 AM
Kimolaoha
12-05-2020 09:32 PM
PelicanParts.com
08-04-2015 02:45 PM
