They're on sale right now at Harbor Freight... do know that none of the adapters work quite right - so you may find that you have to relocate pins on one of them to make it work.
Nothing ! But I am past the stage of just making do with whatever might work. I have learned to get the right tool for the job and then everything goes much easier for me.
You don't need to use any of the adapters for the rears--the prongs on the tool itself work.
Amen! I helped a friend do a set of rears with a c-clamp and have since gotten the tool. At only $20, you can't lose.
What's wrong with a C clamp? The rears need to be compressed AND rotated at the same time. The proper tool for the job (esp. when it's only $20) make things much easier.
This topic has been discussed a million times, but once again, a C-clamp will in fact turn the piston while pushing it in. To me, it's easier to use and I've been in a situation at the track where that tool would not work due to the piston being to far out. My C-clamp worked perfectly.
The tool is fine, but a C-clamp is just as good, if not better in certain situations.
