Anyone running 215/50/16 on their stock X lites?
I am goign to order some tires soon. I'm thinking 215/50/16 Dunlop Direza DZ101. These seem to be VERY close to the stock 195/55/16 rolling diameter size.
195/55R16 vs 215/50R16 Difference = 0.0805% (215/50R16 is bigger)
I'm not lowered, and do not plan on lowering it. Dunlop says that this tire can fit on a 5.5-7.5" wide wheel. Is anyone out there running this size tire on their stock 16" wheels?
Thanks!
Steve
Thanks!
Steve
If you have a 2004 or earlier MCS, you may not want to increase your rolling diameter. While there is nothing technically wrong with doing this (other than a minor speedo error), most folks will seek a slightly smaller rolling diameter than stock to compensate for the rather tall first gear ratio present in pre-2005 transmissions.
FWIW,
Theo
FWIW,
Theo
Thanks!
Steve
Thanks!
Steve
Keeping the odometer/speedometer accurate (close to stock) is important to me and 215/50/16 does just that. For all practial purposes the difference between 195/55 and 215/50 is 3/4 inch wider, all the other dimentions are so close that it's not even worth mentioning. A good web site for tire comparison is: http://www.discounttiredirect.com/di...foTireMath.jsp
Hope this helps...
Kimolaoha
12-05-2020 09:32 PM
Navigation & Audio Impedance of Stock Under-Seat Speakers
jnrjr79
Navigation/Audio
18
09-18-2015 05:51 AM
ltjpunk7
09-06-2015 07:32 AM
sabjcw
08-14-2015 07:40 AM
