Anyone installed this kit? If so, do you lose the parking brake? I can't see how the cable is long enough to reach the calipers new location.
Pictures Anyone?
Thanks!!
Jim
I dont know anyone who has installed this, but if it uses the stock rear caliper (this set does) you would keep the parking brake. There is enough length to the parking brake cables to accomodate the inch or two relocation.
Nope, not enough length. Had to unclip the cables from underneath the car. This gave just enough extra length to fit.
Thanks,
Jim
So there was enough length, you didn't have to replace the cables.
What I meant was.... There was not enough length in the stock location. jeez
Of course had been there ANY instructions with the kit, then I wouldn't have had to ask.
Jim
Maybe you could have asked for my rear rotor kit instructions and have used them? lol
Where were you on Saturday??
From your website:"these kits will require some clearance grinding of the factory caliper cage bracket and are NOT a direct bolt on without this custom work!"
Ireland's kit is a bolt-on, no grinding required AND $69.00 cheaper.
Jim
Jim
Actually I was at Buttonwillow all weekend if you tried to call. Sorry.
Note that the grinding needs are ONLY on the matching Wilwood packages and NOT on the TCE style applications. (it says that if you look closely)
Yes they are more money; for reasons not worth long debates. If you're happy, I'm happy. It's not a big deal too me.
