understanding offsets........
on
Hi gang,
Quick offset question....making sure I am understanding it right.....If you're comparing 2 wheels, say both identical, but one is offset 37 and one is offset 44. The 2nd wheel is 7 mm further away from the centerline of the wheel---towards the STREET side. So that would move the whole wheel IN towards the wheel well????
Is that correct??????
Thanks!!
Thanks!!
Originally Posted by tpetro33
Hi gang,
Thanks!!
Thanks!!
http://www.1010tires.com/WheelOffsetCalculator.asp
The lower the offset, the further it will be pushed out. High offsets will push the wheel inward toward the brakes.
example: the stock S Lites are a +48 offset while an aftermarket wheel is +40. The aftermarket wheel will be 8mm further out than the S Lites.
A spacer of 8mm would make the S Lite like a +40 offset wheel.
GAT
10-04-2015 07:27 PM
bradstyle
10-01-2015 11:15 AM
