Looking for New Brakes. NEED HELP! :D
I just got back from my dealership, and as I expected, my brakes are very low.
The serviceman offered the $400 front brake job but I clearly declined and continued my search for new aftermarket brakes. The suggestions he had for me buying new brakes was to get rotors as well and try to stick with the same company for both. (I think that's bs, but i'm just speculating)
I've read in different threads that Brembo makes good rotors and to check out Hawk brake pads. If the "same company" thing is true, should I look elsewhere?
MiniMania has a set (click here) that they're offering for brakes and rotors but I've read Greenstuff goes fast and has tendency to squeak.
What should I DO?
PS, I have 17's and not much money to spend on brakes and rotors. Do I need spacers too? I'm hoping to spend less than $400.
What should I DO?
lots of discussions on this topic
brembo makes oem replacement rotors for our cars, and they are pretty cheap...
otherwise, for rotors, alot of people have used powerslots with good results... avoid the drilled ones especially for track work as they have a potential for microfractures (not well proven, but i avoided that chance)
for brake pads... mintex redbox are the cheapest oem replacement pads at about 40-50 bucks... but are no better than stock
EBC greenstuff are good ceramic low dust pad, hardly high performance, but better than stock... as for squeaks, just add some auto goop and you are good...
upgrade from that will probably be ferodo ds2500s.. i had those before, dust arent bad, brakes are phenomenal stops, only when thrashed hard on the track do they really start to fall apart... but still, ds2500 stops me time after time... and highly recommended... i still am on OEM rotors when i swapped the front ferodos for the wilwood 12.16 kit...
hope this helped
alot of people would also recommend hawk pads
lastly, spacers are only necessary for bbks, i needed a 3mm spacer for my track 16' wheels to clear my wilwood calipers
hope this helped
on
Questions and Answers
It really comes down to what you want to do with the car. If you want to make athe biggest visual impact then that would be rotors, they will make a slight performance advantage. As a stock size rotor, not much can be done.
If you want better performance (but no visual impact) then a better set of pads will make a huge difference in performance. Now mind you it comes at a price, a better performing pad will have more dust and noise. The DS2500 is a good pad, but I am not impressed with the cold bite and they can be very loud.
Brembo drilled rotors are forged that way. Not drilled post-production. At least for their BBK. I think this holds true for the OEM fitment ones. This obviates much of the argument about microfractures and cracking.
Personally I would go Powerslots and Ferodo pads. Just the fronts. Cadmium coating too so you avoid that nasty rust color....
squawSkiBum
Tires, Wheels, & Brakes
26
03-18-2024 07:21 AM
Tires, Wheels & Brakes
10-01-2015 08:55 AM
