Stripped Lug Bolt--What now?
I took my MINI to my local tire shop to pickup two new tires I ordered and one of the lug bolts was frozen. Once it was removed, you could see all the threads were stripped.
Whats the solution to fix this? Do I need to get a new hub, or do I need to have the hub re-threaded and use larger bolts?
I assume that rotors arent threaded (I need new ones), so replacing my rotors wont fix the hub problem. But should I order new rotors if the hub is going to get rethreaded??
So many questions, no idea what to do.
Richard
Richard
Sometimes the damage is mainly on the lug bolts and not so much on the
threads in the hub. I'd clean up the threads in the hub with the correct size tap,
and see how it goes with a new bolt.
If not, a new hub will be needed.
The rotors aren't threaded, they just have a hole for the bolt to go through.
Thanks for the quick replies. As far as I know, it's the lug bolt that's stripped. I took photos and will post them later. The tire shop was using an air tool to remove the bolts. The other 3 were fine, but this one wouldn't budge, so he removed it by hand with a lot of force. I didn't inspect the hole to see if that was stripped as well.
on
1 Post
Sorry this happened. Lesson learned, always use anti-seize compound on the lugs. When I buy a new car or when I buy tires, I always take out the lugs and coat them with an anti-seize compound and torque them myself after the work is done.
Like Cristo said, If you can find a tap that size, try to clean the thread in the hub, buy another lug nut and torque it down. If it will not hold torque (spins in the hole in the hub) you will most likely have to replace it.
Good luck.
Good luck.
You want to actually use a rethreading tap, not a tap which cuts new threads.
http://buy1.snapon.com/catalog/item....re&dir=catalog
If this doesn't fix the problem then it is time to replace the hub.
I believe the correct size is M12x1.5. Anybody else know any different?
Originally Posted by OctaneGuy
Thanks everyone for the tips! Will have to make a trip to the dealer and buy some more lug bolts. Not sure about the tapping thing though--about whether I should just find a shop to do it for me.
We can work out a deal for online wrench advise in exchange for a deal on a VacuCam system
YES! 12x1.5 IS CORRECT!!!
A rethreading tap will clean up borked threads, but there has to be threads to clean up. What it is doing is reshaping the treads that are already there. Like has been said you may be lucky & find the the lug bolt was the only thing stripped. If not a new hub is in your future. If there is any doubt Richard, play it safe & get a hub.
I had this happen on the Cooper before I went to studs - one of the bolts in the rear hub must have gotten really hot at an AX, so much so that it stretched a bit. When I took it out, it galled the threads in the hub all to heck - to the point that it was not save-able by re-threading the hole because it actually removed material.
I drove home with 3 bolts, stopping every little while to re-torque the bolts.
When the new hub went on, the bolts were replaced by studs...
If you go with a re-threading tap, be sure to squirt plenty of oil into the hole before you start, and periodically back the tap out a quarter-turn as you're running it through the threads. I usually turn the tap a full turn clockwise, followed by a quarter-turn anticlockwise, then another full turn clockwise, another quarter-turn anticlockwise, and repeat until the tap is all the way into the hole.
The reason for this is that the tap will have grooves in it to collect the metal shavings/crud that you're cleaning out as you clean/re-cut the threads. Periodically backing the tap out gets the crud into those grooves and out of the threads.
Only thing the tech asked me to do was to retorque the big nut holding the hub on at some point, so I got my neighbor to stand on the brake pedal and I tightened it to like 147 ft/lb or something. All's good......
I don't have my Bentley in front of me but I think it's like a T50 for the rotor, and I think I used a 1 1/2" std 6-pt socket for the hub nut that fit fine (don't have a metric socket that big). This is all from memory and it's early.....
Coordinator :: STLMini
on
I had one hole that was stripping out as well, so I switched to the best studs (hardest metal) I could find (Turner Motorsports). They were almost $6 a piece, but I haven't expereienced the backing-out issue mentioned above (an occasional Auto-X class or DE).
Perhaps you could get someone to clean up the threads with a tap... just enough to get a stud in there and fixed so you wouldn't have to mess with the threads again?
For the R56, the big bolt is a 52mm and the rotor torx is size 47. One of the bolts on the back seems like you can't get to it with a socket, but it is possible with an extension...you have to go at it sideways between the ridges of the CV boot and then get it perpendicular to the bolt.
IQRaceworks
53
06-28-2024 07:29 AM
patsum
26
05-29-2021 06:29 PM
Interior/Exterior Chrome strip above license plate, who makes black ?
got_mini?
10-07-2015 02:12 PM
