16 inch rims with JCW BBK
on
on
The JCW brake kit will fit under the R84 (X-lites)
The Phil Wicks MINI had the JCW brakes mounted with the R84 rims. I talked to them about it, and the only problem seems to come in when a shop goes to put balance weights onto the rim. They may have to be shaved to clear the caliper properly. It is a VERY tight fit, but it can be done.
on
Originally Posted by goaljnky
Actually, TireRack only comes back with 17teens. But I will check again. Wish I could affort the SSR's.
on
Originally Posted by ICEMAN
How's this? 16x7.5 Kosei K1 wheels over JCW brakes, and the wheels are light and cheap from Tirerack. FYI-I sent these pics to Alex from Tirerack but I see they still don't approve these wheels for the JCW MCS.
Those would work, but TireRack doesn't show them anymore. Maybe they are out of stock. What did they cost you if I may ask?
I bet those 16x7 O.Z. Ultraleggeras would fit, and are only 14.5 lbs. The reason I'm sure of thise is if you look at the pics of my car, you will see that the rim comes nowhere near the caliper, it's the spokes that are the closest. The Kosei and Ultraleggera wheels have spokes that start at the edge of the rim and go to the centre, providing lots of clearance.
07-16-2020 12:54 PM
squawSkiBum
10-02-2015 09:21 AM
