Steering Wheel Wobble, intermitent
Heya all, I'm having some steering wheel wobble, and am wondering if anyone may be able to help me track it down. My definition of steering wheel wobble is that 'the steering wheel shakes back & forth a few mm, but not enough to impede normal operation of the steering wheel'. The history:
Got new wheels, wrong hub size, no hub rings. Massive wobble. Removed wheels until I got the hub rings.
Installed wheels w/hub rings, the wobble was completely gone from the steering wheel.
Got coil-overs, and lowered the Batmini waaaaay low for the Dragon. Got some nasty vibration on accelleration due to the CV joint angles. Vibration only occured during accelleration, no wobble or vibration otherwise.
Took back to tuner, and raised the front up about 1" to fix the CV-joint angle issue. No more vibration. Wobble is back.
But it's not like it was before. Before it was wobble wobble wobble (before the plastic hub rings). Now it's sometimes. I feel like if I'm driving down the road, it's either wobbling or it's not. If I go over a bump or trammel a bit in some of the wonderful maryland road ruts, that the intensity of the wobble can change, start, or stop.
I removed the wheels, verified all the hub rings were still in place, and ensured the wheels were torque'd down to spec. Wobble dissapeared... For a couple days. Maybe I didn't fix it at all, and it just decided not to wobble for a bit because it comes and goes.
So that's the history. I'm using plastic 56.1-73mm hub rings and am wondering what types of things could cause this intermitent (not all the time) wobble. Maybe it's the plastic rings? Front wheels the rings popped out easily, rear wheels the rings were both wedged in pretty tight. I'd think if it were a bent or misaligned wheel that it would wobble all the time, and not just sometimes.
Anyhow, I think it's more likely that it may be a wheel tire thing than a suspension thing, so I thought I'd give it a go here. Any ideas?
Wheel balance can do this, if both front wheels are slightly unbalanced to roughly the same degree.
Sometimes the vibrations from the wheels cancel each other out, and sometimes they add together,
depending whether the imbalance of one wheel is in phase or out of phase with the that of the other
wheel.
If the wobble comes and goes at regular intervals when traveling on an extended slight curve in the
road, but stays the same in a dead straightaway, this is probably the problem.
wheel.
Originally Posted by fj0
Can you tell me more about the CV joint angle issue? I have a "wobble" in the whole car, not just the steering wheel during acceleration from 30-50kph. I'd love to hear a fix for this, other then raising the car!
Thanks in advance.
Thanks in advance.
https://www.northamericanmotoring.co...39#post1016832
Yeah Joker, I'm going to get metal rings.
I think I have about 11k on them Cristo. I wonder how difficult it would be to get these balanced again. Getting someone to balance them would also (in essence) test for wheel warping, yes?
Originally Posted by Wagnbat
here ya go:
wheel.
wheel.
This is the only reason I can offer for my intermittent wobble. I experiemented until the wobble went away. I install each wheel in the position now. Of course, as tires wear, this may mean little.
Originally Posted by jfunkmd
The shop that mounted them for you shoul doffer free lifetime balancing. I know Discout Tire does!
And I don't know how true that is Meb, because when you turn a corner, the inside wheel travels a shorter distance than the outer wheels and thus would be out of 'alignment' by your comparison.
Originally Posted by meb
I would add, and this is only speculation based on my own observation, that in and out of phase can occur when wheels are removed and placed back in a different orientation; lets say you remove and reinstall the left front wheel and none of the others. If you reinstall the wheel in a different orientation, what was at 12:00 is now at 3:00, the wheel weights are now in a different orientation with respect to all the other wheels.
As wagonbat mentioned, the wheels rarely travel the same rotation
with respect to the other 3 unless you're going straight the entire time.
i think the wheel is still out of balance and when the rotation of the
two front wheels resonate at a given frequency, you get that wobble.
i would have the front 2 wheels re-balanced on a hunter machine.
i also don't understand why you would slam the car because you're going
to the dragon. i would do the exact opposite. I would setup the car to
your driving habits by refining the bound/rebound characteristics near
stock height where sus travel and geometry is not compromised. i would
slam it if i was going VIP style.
I had the coil-overs the week before MOTD, so I didn't really have time to tune up/down. But I'm comfortable with the current height, so long as I can get rid of this wobble. I suppose I'm going to have to get the wheels rebalanced somewhere. Just no idea where, because a shop up the street wants about $70 to do it.
My steering wheel wobbles also. It used to do it occassionally and now it does it constantly. I had my tires rotated and balanced in mid June. I don't remember if it did it before, I don't think it did come to think about it. But I'm also pulling to the right, going to get my alignment checked.
I only paid $13 for my rotate and balance.
tha hunter machine Ken talks about is mostly needed on big tyres/wheelz like 19's on up^^
70bux is a lot 'o dough, i paid 150 to mount 4 235.35.19's 'n even that wuz high
07-16-2020 12:54 PM
Manny_cooper
09-10-2015 11:09 AM
trw92a
08-26-2015 01:47 PM
Navigation & Audio Steering wheel controls for music
MES11
Navigation and Audio
08-06-2015 08:52 AM
