Tire rub
Tire rub
I installed a set of General Exclaim 225x45x17 on my MCS to replace the NF. What a difference; I'm a shame of myself to wait for so long.
I love the new tires and the improved steering feeling; however with three people in the car and spirited driving there is a little rub at the 2 o'clock - facing the left rear tire - area of the inner fender well plastic linning not the exterior molding lip. Could I just gring some 3mm off? What is behind the linner? Should I let it just wear out? Comments?????
You don't need to grind off the 3mm of rubber- it will wear down with use and from rubbing the inner wheel well which is only black plastic- no harm rubbing the plastic down either. I let mine wear down after I had added H-sport springs. Seems to be no harm done. Makes some loud rubbing sounds though- scares my wife a bit-impatientimpatient:impatient impatient
Thank you. That's what I thought but now I feel better :-)
I took the rear tires off the car last night and inspected the entire wheel wells. The right one rubs approx. 3mm and the left approx. 2mm both located about 30* from vertical towards the rear. Agree with you, it will take few more "rubs" to go away.
The 225x45x17 ( non-RF ) tires improved the entire handling of the car. A lot smoother, and more predictable w/o being jerky.
When I decided to go with the 225 on the original S-lites, after lots of meausuring, I added a 5mm spacer all around. After installing the tires and go real spirited driving with two people on the car, the car is not lowered that's next - got a small rubbing on the rear - the fronts are perfect. Removed the rear spacers and bingo!!! what a difference. Guys, that's the way to go!
What a difference of the car, the handling is so much improved, really smooth and more predictable than with the RF's, and the look and stance is superb.
I'm thinking of putting 17" wheels with an offset of 42 and THEN adding a 5MM spacer to push the wheels to very outside of the fender arch.
WIth 205's on the tire do you guys think I will get any rubbing on a non-lowered "S"?
What's your guess?
Originally Posted by Ministi2005
If I recall the S-Lites are about 48 offset?
What's your guess?
What's your guess?
You don't need the spacers for 17" aftermarket rims with offset of +42mm. The acceptible range is about +37 to +50mm.
Using 205/45-17 tires you won't rub with or without spacers.
Personally I think it is better to install the wheels with no spacers- the +42mm offset is fine.
Supertractor3
04-07-2017 11:16 AM
