Drove 5 miles on a flat runflat Is the tire shot?
Hi All,
I hit a pavement break caused by ground down blacktop no longer level with cement. Instant depressurization was the result, not to mention a dented R85 S-lite wheel. So here is my question.
I drove approx. 5 miles on the flat and kept the speed well under 50 MPH. Is the tire re-usable? It looks like the tire will clean up fine, with just slight scrape marks on the sidewall. What I don't know is if the sidewall has been compromised. All opinions appreciated!
Mike
Mike
It's probably toast...
the sidewalls of runflats are very, very stiff. If you hit hard enough to dent a rim, the sidewall had collapsed completely during the impact. If you really want to try and see if they can be saved, you have to have them dismounted and inspected on the inside as well.
Another way to go is to thing of this as a unique opportunity to go to a conventional tire.
Also, submit a claim to your state department of transportation. You may get it approved, and it will take a while, but a check will show up in your mail box. I got $600+ for a windshield based on rocks that hit mine in a construction zone.
Matt
Matt
More than likely the sidewall of the tire is damaged. They have metal reinforcement in there and if the metal is bent it will weaken the tire and make for an unbalanced ride. That could lead to heat build up and a blow out. The tire shop the fixes you tire will be able to tell you for sure depending on the damage to the tire. I don't think the 5miles of driving it is enough to significantly damage the tire but the impact could be.
Thanks for the input
I have a new tire and R85 on order, which I'll pick up on Friday. My plan is to document carefully and go after a reimbursement from ODOT. I believe with a little perserverance, I'll get my money back. Interestingly, the pavement break I hit now has a blacktop ramp and is marked by "Bump" signs. If only someone would have done their job initially .
Thanks for everyone's input
Mike
Mike
07-16-2020 12:54 PM
ltjpunk7
09-06-2015 07:32 AM
Powershift
08-16-2015 05:14 PM
