wheel spacers and lugs
I would like to push my stock holies out a bit.
I want to add spacers:
but I don't know what size to go with. Mini Madness offers them in 5mm, with which I probably wouldn't have to do a lug conversion, 8mm which will probably look and fit the best, and 15mm which would almost definitely need a lug conversion.
My question is: Would I need to do a lug conversion if I went with the 8mm spacers? I don't want to go 15mm, too much, and 5mm seems to be not enough. If I'm doing it I may as well do it and go 8mm.
Then: With lug conversions, Helix13's is only $50 (good) but does it retain the stock length or add some so it will work safely with the spacers?
Or I should do the madness kit which is $150 (pricey) But is available in two different lengths, 3in or 3.5in.
I would appreciate anyone with knowledge about this to chime in!
Thanks!
-Steve
Thanks!
-Steve
Mini'mon
08-16-2015 04:15 PM
Rennfahrer555
08-13-2015 09:07 AM
