Will 15" Stock Mini Cooper Wheels work on an 80s VW?
07-30-2006, 01:51 PM
on
I know that the offset and wheel bolt pattern are similar but I am not too sure about the center bore. Has anybody tried it?
07-30-2006, 01:56 PM
VW's are 57.1 mm (MINIs are 56.1 mm)
so a VW wheel will fit loosely on a MINI (not recommended),
but a MINI wheel will require machining to fit on a VW.
07-30-2006, 02:08 PM
OVERDRIVE - Racing Champion
OK, then put MINI hubs on the VW, then the MINI wheels will fit.
A machinist should be able to bore out 1 mm of the MINI wheel to enlarge the centerbore but then it wouldn't be so good as a MINI wheel anymore.
07-30-2006, 03:06 PM
on
The mini wheels will work on an 80's vw if bored out. Polished holies with 10mm spacers on a MK1 would be sick.
VW wheels will work on a mini, but they will not be hubcentric. I've driven around on bbs ras from a vw with no problems.
07-30-2006, 05:28 PM
Coordinator :: River City Minis
on
you mean something like this
took 20 mins per rim to grind them out with a dremel to make them fit.
SosoMINI
11-22-2015 03:17 PM
phrza81
10-10-2015 11:37 PM
Mini'mon
08-16-2015 04:15 PM
nomar116
08-09-2015 09:42 AM
08-07-2015 08:02 AM
