Will I rub w/ 5mm spacers?
I've been looking at buying the 13" TCE Wilwood brakes. I read somewhere that 5mm spacers are required if I run my stock 17" S-Lites.
I have the M7 progressive springs, so it's ~1.3" lower than stock. I'm running 205/40/17 tires, but plan to go with a taller tire (205/45/17) next time around.
So, my question is, will I rub?
Thanks in advance,
Gary
Thanks in advance,
Gary
I'm using 5mm Eibach spacers with my S-lites with 225x45x17 (20mm wider and 9mm taller tire than the one you want - with stock suspension) and have minimal rubbing on the rear when loaded (i.e. 2 adults w/some weekend bags) and VERY spirited driving. The rubbing is - not on top of the fender lip as expected - around the back 2 O'clock area.
IMHO you'll have no problem w/your choice.
freeman727
12-10-2017 04:00 AM
wildwestrider
11
01-29-2016 05:06 PM
