i'm on 215-40-18 with no rubbing..although my tires are practically bald now I would think you'd have to worry more about the width-215 or 225..not so much about the 35 or 40's (height)..although if you go 225, you must do 35's...so make of this what you will
Saakey,
Is your suspension lowered? I am on 215/35/18 and although I have no rubbing I feel I could use alittle more cushining
Yes, very ... look in my gallery and you shall see more And I take that back a bit...I did have slight rubbing in the rear over/under swoops that would cause suspension compression....but it was just on the plastic liner underneath...which I think just eventually wore down to where it stopped.
