Factory 17" Webspokes
#26
Hey Astro,
This is kind of OT but.. I just replaced my webspokes with some 18" gunmetal rims with a reflective white (deep) lip. I'm going to take some pics this weekend after I wash it up.
I've followed this thread since the beginning and was considering painting my webspokes out but then I went the Brembo route.. and the webspokes just wouldn't work for me anymore.
Looks Awesome Partsman!
#28
#29
Scott
#31
Sorry Chad (and Partsman).. I my fingers werw moving faster than my brain when I compliemnted Patrsman instead of you...
Scott: The Webspokes didn't fit over the brembo's.. Cosmetically I think they're the best looking stock 17... but I kind of wanted something a little larger.. and deeper.
Personally I think that Mini should've offered the webspokes factory colormatched as an option. I think it looks fantastic painted out. I'll be washing the money pit tomorrow and I'll take some fresh pics of it. I updated my sig with a photoshopped version of the rims. It gives you an idea of what it looks like.. but with the white trim rings, the lip looks huuuugggee.. Anyway.. I'll post 'em when I get 'em..
#32
Well.. here they are... Without bogging down this thread with Off Topic pics, click the link below for my Axis TC Evo folder in my gallery.. I initially didn't run the white (technically "reflective silver", but they look like reflective white to me) rim lip rings but I think I like it with them on.. it pulls in the white roof and stripes..
I'm debating on dropping the stripes..
Axis TC Evo Pics
Axis TC Evo Pics
#35
#36
I would feel safe re-using the ones that are on the wheels, though. Considering that the torque spec is only 24 lbf-ft, I doubt seriously that they're the "use once and discard" type that permanently deform the first time you use them. Those are usually torqued to significantly higher values, and are used for things like cylinder heads, connecting rods, and main bearing caps.
Make sure you use threadlocker when you replace them, and re-check the torque several times over the course of a week or so.
Scott
#38
#39
If there's something else to keep the center piece from rotating, then the perimeter fastening bolts won't have much shear stress on them during operation, and all they have to do is hold the center piece snug to the hub - the notches or teeth will absorb the forces during use.
With a cylinder head, it's the stretching of the bolt that actually provides the clamping force to keep the head attached to the engine block, and there's nothing else that provides that clamping force.
I'll make my final decision once I have my webspokes taken apart, but I'm really not seeing why the perimeter bolts would be the "use once and discard" type.
Scott
#40
My understanding is that all bolts apply force by stretching at least slightly. Either the substrate crushes, or the bolt stretches, or some combination of the two. Block bolts need to apply a very exact and repeatable amount of force, which I'd imagine changes after tightening/heat and tension cycles. Perhaps that's important in this application, perhaps not.
Regardless, I'm only advocating doing the research (which I don't have time to pursue right now). Seems that Ronal would have said something about new bolts with that torque spec, so I'd imagine the old bolts are serviceable. I will be looking into this more deeply when I do this to my wheels next summer.
Cheers.
Cheers.
#41
#42
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
09-10-2015 11:55 AM
09-04-2015 02:34 PM
09-04-2015 11:43 AM
