question about tires
on
Originally Posted by TEDDYGP
hi i have a question ,i just order a set of volk racing ce28n 17x7.5 +43 offset and i want to know can i use 215/45/17 tires (my cars is lower) ,because my freind tell me it will rub so is that true.thanks
If you get slight rubbing it will be on the inner upper outer edges of the plastic inner wheel well on the rear tires. Some plastic and some rubber on your tires will wear off. If the tires are worn then there is likely to be less rubbing. When you put four people in your MINI the suspension is compressed and this increases the chance for rubbing especially over bumpy uneven roads.
Another adjustment you can make is to make the rear negative camber a little more negative so that the tire edge clears the wheel well. Any negative camber from -1.8 to -1.0 degree is fine for the rear.
on
Mini'mon
08-16-2015 04:15 PM
jrezzo
08-09-2015 10:32 PM
