Tire Swapping: Alignment needed?
Hello!
When I get my car, a MCS, that day or the next the 16's come off and my 15 konig rewinds go on.
The tire height is 6.01 mm taller which is as close as I could get. So radius wise its like 3 mm increase in height either direction. - side note
the old is 195/55/16, the new is 205/60/15.
Do I need an alignment or can I just get out the wrench and do the job myself?
Originally Posted by El_Jefe
Hello!
As your suspension drops you will have less clearance and sometimes a bit more negative camber will help with wider or taller tires to fit in the wheel wells without rubbing or with minimal rubbing.
Normally for 15" rims we see 205/55-15. You should be fine with no need to realign.
Yeah I know that 205/55/15 is very standard. I went taller as that is actually closer to the original height than 55. I do not care about off the line acceleration, I am much more of a mid game type of driver.
I considered getting 225/50/15 I feared snow and rain though. All of that money for LSD and DSC and I would spin on account of tires being too huge for the weight of the car.
I thank you all for your advice and tips.
Some good competition tires in this size but also requires wider 6 to 8" rims (so not ok for stock 15x5.5" rims). This size (24") also a little smaller than stock size outer tire diameter.
BF Goodrich g-Force T/A Drag Radial $118
Kumho Ecsta V710 $160
Kumho Victoracer $138
Michelin Pilot Sport Cup $207
Yokohama Advan A048 $193
driving wise or looks?
somehow, all the corvette people have these enormous tires (compensatory) on their cars. I always thought that they must be terrible in the rain as it would trap water easily. but, people always talk about how wide tires are better. I duno. I got 205's as it is on the edge of being rather wide for the car but not into 225 category like my 88 camaro had.
hello Crashton!
hello Crashton!
Jefe,
For me it's looks & driving dynamics. Lets forget about looks, because that's a personal choice. The bigger & heavier you go with tires the more it effects handling & braking. If you are going to pound around a race track a wider tire is worth the weight penalty, more grip = faster lap times. In the real world were most of us drive a narrower tire will work better. Like you mentioned in rain, less problems with hydroplaning. In snow I'm a believer in 4 real snow tires on the car. The size you've picked should work well for you.
Others may have their opinions, these are only mine.
Yep Corvette's have steam roller sized tires on them. My best guess as to why is they were designed to have them. Looks plays a huge part, but so does the HP they must contain. I wouldn't be very keen on driving one fast in the rain.
Cars with 2x the hp and torque in the 60's had half the size tires and seemed ok!
shrugs.
shrugs.
07-16-2020 12:54 PM
Minibeagle
08-13-2015 10:00 AM
Rennfahrer555
08-13-2015 09:07 AM
minipopkart
08-13-2015 05:22 AM
