A048 question...
I use them only for track not as a daily street tire, they are standard issue on Lotus Elise as a daily use tire but with the visceral sound of the engine at your back you can't hear tire noise just the sweet sound of the motor, on our cars they are quite noisy on the street, every time I drive from the track to the hotel they let me know that they are not for daily use, on the other hand they last a real long time on the track. I have 29 track days on a set with lots of compound left.
Thanks, I guess that answer my question,..... they are suppose to be loud .
How do you run them in thou?
JOHN
There are no special procedures since they are considered street tires and not racing slicks, if they were being used as track only tires then I would try to get them heat cycled right from the dealer or I would run them for one session and then let them cool down for 24 hours before I put them to regular use
Couple of hot laps? Sorry, I have no clue other than just putting miles on them, but on the street that won't qualify as a heat cycle, correct?
I'm interested to hear an answer to the above question. Anyone else running r-comps on the street regularly?
mb
mb
let's just wait
You'll be fine.
FYI, the road noise only gets worse as the tires get worn down. They aren't too much worse than the original 215 Azenis in that regard though.
I've about polished off a set of 225/50-15s, using them for auto-x rain tires as well as a couple thousand miles of street use. I've driven them to numerous events with the dry weather Rs in the back so I'd have both available.
Scott
90SM
Scott
90SM
Find an empty parking lot about 10 minutes of a tight figure eight then go home take them off the car and let them sit for 24 hours, hoosiers need to sit for 72 hours if you want them to last any time.
If the noise is severe try calling Alex@tirerack.com and ask about that problem for the A048 tires when used on the street.
I have Michelin Pilot sport cups I use on the track and when I have them on the street they are fine. Not overly noisey but not super quiet either. They seem ok with windows down or up.
You don't want to wear out your tires too much but run it a little is OK.
Given Alex a call on the phone or even send email.
JOHN
My best results have been acheived when I ran about 4-5 laps. The first lap is super easy, the next few are progressively more demanding until the last, which is almost 10/10ths. Take care to avoid big slides and lock-up. Then bring the car in and get the tires in the air, either by putting the car on jack stands or removing the wheels from the car and stacking them. Then don't use them again for a minimum of 24 hours. Oftentimes 48 hours is recommened, sometimes even up to a week.
This process of slowly heating the tires, breaking the weaker (chemical/molecular) bonds, and allowing them to re-form will substantially improve the wear and consistency for track use. It's worth doing, believe me.
I've never had any luck with the figure-eight technique. As badly as I wanted it to work, it didn't seem to help much. I have a friend who gets good results from Tire Rack's heat cycling service. Again, as badly as I wanted it to work, it also didn't seem to work as well as doing it the old-fashioned way. Your results may vary, but heat-cycling track tires on track seems to be the best way.
Best of luck. And let us know how it works out for you.
MSFIT
42
05-02-2006 11:06 PM
