Warning Light After Tire Rotation?
I rotated the tires front to rear yesterday and then while driving around the Tire Warning Light came on. I pulled over and checked the pressures and they were all good. So I pressed and held the reset button, drove for about a minute and the light went off. It never came back on again.
I need to read the manual (the wife has the car right now), but I don't think just pressing and holding the reset button will actually reset it....will it?
Any thoughts on what happened? Will this happen everytime we rotate the tires?
The tire pressure warning light has to be reset after rotating yout tires. As stated in the owner's manual, start your car, hold down the button on the center console until the light comes in the speedo, then you are set to drive off and the light will go out. this resets the tire warning system.
I have rotated my tires before without resetting the light. As long as all four tires have the same pressure, you should be fine.
The sensors detect rotation speed of the wheel/tire and not the actual pressure.
'03 Same thing just push the button hold whether driving or not. I had two scares last time. I had the Dealer in St. Louis rotate them and almost lost a tire on the way out. Left front lugs not tightened and the pressure light came on. Got it back to dealer for red faced apology and explanation of the low pressure light.
No biggie. Mine's done it 5 out of 7 times I've rotated my tires,
but I check all tires for correct pressure whilst executing the rotating.
So I just reset and go on my way.
Now...if it comes on at any other time .....I'm off to the side of road pronto!!
...Les
07-16-2020 12:54 PM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
