Getting new wheels/Brake Dust
Silver with Machined lip
Black with Machined lip
Chrome plated
Probably the finish to worry the most about would be the Chrome plated. Corosion can occur and ruin and pit the chrome- you must keep it clean.
I have seen chrome get messed up in less than a year if you don't regularly clean the brake dust off.
Waxing the wheels only helps a little. Wheelwax is supposed to help but it doesn't last. Smells good.
![Nod](https://www.northamericanmotoring.com/forums/images/smilies/nod.gif)
Changing brake pads to something that gives less brake dust is probably the best thing you can do especially for the front brakes. Mintex Redbox and EBC Green pads are common choices. Both have less dust than stock pads and perform OK for street use. The Mintex pads are half as costly as the EBC greens.
Keep your wheels clean about once weekly is OK but over time the finish will be beat up and dull. Takes about 2 to 3 years.
Black would be easy to neglect and still look OK but you have to clean it now and then.
The R1's spoke pattern is not the most friendly but it's OK. Some people use a brush wheel cleaner with a handle that seems to work.
I have BBS RGFs which are similar design, and found that changing pads to Hawk ceramics (Mintex Red Box would work as well) really cut down on the brake dust. For cleaning, I use a brush made for the purpose (I think mine came from Griot's). I like to actually use a second, small bucket of the same wash solution & water, dedicated for the wheels - don't want to get the brake dust & other grime onto the wash mit that you use on the rest of the car. With a light coat of synthetic wax/glaze occasionally, the brush and soapy solution cleans my wheels just fine, even w/o a spray-on wheel cleaner.
ASA R1 is which finish?
Chrome plated
Chrome plated
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
