195/50/15= too small?
I'm rolling on 205/50/15s and understand what its like to have the shorter diameter. Is the 195/50 size TOO Small though? I want to get 195s for a new set of wheels, but the 195/55 sidewalls are a bit too big and the next smallest option is the 195/50
This is for a daily driver that then competes in the STS class at autocrosses with those daily driven wheels+tires.
Thanks all.
Thanks all.
Don't know if it's TOO small, but the diameter difference is 23.07in vs 22.67in for the 195/50, which will make your speedo 1.7% faster. Got it all here:
http://www.1010tires.com/TireSizeCal...?action=submit
mb
edit - I think I read somewhere that it's good to keep your overall diameter close to 24in., but I'm not certain on that.
mb
They will be fine. My girlfriend has that size on her MINI and there is no issue at all. Speedo is off but she doesn't care. Lowers the car about a half inch and increases the gap between the fender flair and the tire. Her car is the one with the white top. Mine has 185/65-15, very near stock size.
Click the image for larger size.
![195/50/15= too small?-winne-and-constance.jpg](https://www.northamericanmotoring.com/forums/attachments/tires-wheels-and-brakes/19069d1481845524t-195-50-15-too-small-winne-and-constance.jpg)
![tongue](https://www.northamericanmotoring.com/forums/images/smilies/tongue.gif)
I may still rock the 195/50's though... It's hard to stretch the 205s on anything that fits under our car
on
I dont know man.....I love low-ness and all. Believe me. But even with the 205/50's, in order to get rid of all the extra wheel gap....you are basically dragging subframe ![tongue](https://www.northamericanmotoring.com/forums/images/smilies/tongue.gif)
![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
If you ain't dragging, then you ain't low enough. Haha j/p.
Idk, your car is pretty damn low.
I guess theres really only one way to find out. Maybe try out out with 2 cheap *** tires (maybe even used, wasted) on just one side to see how the car will sit. Then take it from there... ![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
![No](https://www.northamericanmotoring.com/forums/images/smilies/no.gif)
on
Personally, I say go with the 195/50's... Take some pics when you do a test fit with the new wheels you picked up
I know that you are looking for some stretch, but I think the 205s are a better compromise. I know you run your car very low, but they'll fill in the wheel wheels much nicer on your cooper.
That said, I ran 195/45/15s on 15x8s on my Mk2 VR ... H&R Ultra Lows. But it is much easier to pull that off on a VW.
For some strange reason I like a bit meatier tires on a MINI ... but that's just my opinion. I'm even tempted to run some 225/50s on some 15x8s.
![Eek](https://www.northamericanmotoring.com/forums/images/smilies/eek2.gif)
the look is important - but you realize that the 195/55/15's sidewall is 4.75 millimeters less than the 205/50s - i.e. less than 1/5th of one inch different? (.187 inch to be exact).
For some strange reason I like a bit meatier tires on a MINI ... but that's just my opinion. I'm even tempted to run some 225/50s on some 15x8s.![Eek](https://www.northamericanmotoring.com/forums/images/smilies/eek2.gif)
So besides peoples' opinions on what looks right etc.....is there a safety hazard to the smaller wheels? The tire calculator warns that above 5% difference from stock could cause brake failure. The 195/50's are just above 5% difference. If the speedo is a bit off...I'm fine with that, but i dont want brakes failing
![Sly](https://www.northamericanmotoring.com/forums/images/smilies/sly.gif)
Jason
Thanks all.
Thanks all.
Otherwise for street driving it's OK using 15x 5.5 to 7" wide rims.
Outer tire diameter is a shorter than stock 22.7" but best part is you can buy
Goodyear eagle F1 G3-D3 tires for $93 each
280 treadwear AA traction 19 pounds, V speed rated
Excellent tires and the only size in 15" available.
In 195/55-15 in Ultra High Perf Summer tires:
General Exclaim UHP $56
Michelin Pilot Exalto PE2 $109
Kumho Ecsta SPT $63 closeout
BF Goodrich g-Force Sport $72
Avon Tech M500 $69
Dunlop Direzza DZ101 $66
Outer tire diameter 23.4" and closer to stock sized. These tires will also work fine with 15x 5.5 to 7" wide rims.
10-01-2015 12:34 PM
10-01-2015 12:34 PM
10-01-2015 12:28 PM
10-01-2015 12:28 PM
10-01-2015 12:13 PM
