MCS late 06 brake change?
I believe the changeover was on 8/06 builds and later... They have larger diameter front rotors... which are also clearanced for the 14mm lug bolts. However! There seems to be a bit of inconsistency on 7/06 builds!
In essence, all later models ended up with JCW brake kit sized front rotors...
The rear rotors didn't change, although, I do believe that MINI had the bolt holes opened up a bit...
07-16-2020 12:54 PM
