Dunlop Direzza DZ101
Ask Alex@tirerack.com about any feedback he's gotten.
Direzza DZ101 offers good value- Probably OK for street use with a MINI.
Some owners report they did OK with it at autocross.
Available sample sizes for the MINI:
195/55-15 for $66
300 treadwear A traction V speed rated 20 pounds
205/50-15 $57 20 pounds
205/55-15 $70 21 pounds
205/50-16 $77 21 pounds
205/55-16 $74 22 pounds
205/45-17 $90 20 pounds
215/40-17 $88 21 pounds
215/45-17 $85 22 pounds
215/35-18 $106 21 pounds
Tirerack.com test results
http://www.tirerack.com/tires/tests/...ay.jsp?ttid=78
Tested on 2006 BMW E90s:
Avon Tech M500 Ultra High Performance Summer 225/45R17
What We Liked: Quiet and comfortable road manners along with good wet and dry traction
What We'd Improve: Sharpen dry road steering response somewhat
Conclusion: A well-rounded Ultra High Performance Summer tire that is easy to live with everyday
Latest Test Rank: 1st
Previous Test Rank: 2nd (April 2005), 1st (Fall 2004), 1st (May 2004)
BFGoodrich g-Force Sport Ultra High Performance Summer 225/45R17
What We Liked: Good dry traction and sporty handling
What We'd Improve: Increase wet traction and reduce tread noise
Conclusion: A responsive tire that performs well in dry conditions
Latest Test Rank: 3rd
Previous Test Rank: 2nd (Fall 2004)
Dunlop Direzza DZ101 Ultra High Performance Summer 225/45R17
What We Liked: Responsive road handling
What We'd Improve: Some more dry grip and much more wet traction
Conclusion: A responsive tire that needs improvement in wet and dry traction
Latest Test Rank: 4th
Previous Test Rank: Not previously tested
Fuzion ZRi Ultra High Performance Summer 225/45R17
What We Liked: Good wet and dry traction
What We'd Improve: Reduce tread noise, slight improvement in steering response
Conclusion: A good all-around Ultra High Performance Summer tire that really does perform well
Latest Test Rank: 2nd
195/55-15 for $66
There is also bias from each owner that writes a review on tirerack.com about the tires on their individual cars.
Everything you read including our opinions on NAM are to be taken with that in mind so you are correct in being careful.
It's helpful to form an opinion of your own from experience or from doing performance driving and seeing how difference tires do under different circumstances. There is great variety and many differences out there to appreciate. If you have the inclination, try to visit Tirerack in Indiana or spend some time talking to Alex@tirerack.com if you have tire questions.
They have excellent tire testing facilities and quite a well established program for comparitive testing.
I have always found Alex to be honest and knowledgable about tires well suited for the MINI. Realize that the MINI is a special car. Good for the street but with a very large performance envelope. You wouldn't really want to put your average touring tires on the MINI but you could if your driving needs were best suited for those tires.
Heck, I have stock Conti all season 175/65-15 tires on my modded autocross MCS for daily driving and it's working just fine but I don't push it too hard (they aren't Max Performance summer tires).
Good luck in your decision. Talk to owners in your area about their experiences.
I put 215/50/16 Direzza's on two weeks ago and have been happy so far. They seem to do as well as the Avon M550's we had on the Cabrio, but are sharper and more grip (to be expected from a summer tire). They are still perfectly acceptable for ride Q...smooth.
Just bought a set of 205/50-15 @$57 each with a $50.00 rebate.
They are going on 12.5 lb. Rota Circuit 8's. This combo will net 32.5 lb. per corner with a 23.1 diameter tire which is like adding a 05 transaxle and 20hp. Well maybe not 20hp, because I don't know the calculation for the weight loss to hp. Compared to the OEM run flats on S lites at 48 lbs. each that’s 15.5 lb. less weight per corner. I run those S lites in winter with the all season run flats. My other summer wheels are shod with Yokohama's AVS ES100 205/50-16 on Rota Slip Streams. This set-up is for fun.
Zoom, zoom.
I know there are better tires out there but not at this price.
Zoom, zoom.
If you can get decent performance for your needs at that kind of price point then great.
What I like is if it wears fast or doesn't last quite as long then your investment will have paid for itself quickly.
I got some $200 a piece Bridgestone S-03s I'm trying to wear out a little more before I switch. Same with my $200 a piece Michelin Pilot sport Cups that are also old and need to be used a little more. Both sets are usable but close to retirement.
Makes me happy to think of new tires soon (someday). Not going to replace them with the same tires.
sabjcw
08-14-2015 07:40 AM
