19"
Old 03-25-2007 | 07:34 PM
dxl007's Avatar
dxl007
19"
Hi all,
I'm new to the forums so Hi.
I have a 2007 MCS and would like to put 19" on it.
I know, I know, it will slow the car down ect, but I like to do things a little different then most.
I had a 2003 Evo VIII on 19X9's and still ran a 11.7 in the 1/4 mile, so it can be done. (stock motor, head, and turbo no NOS).
I waited till 2007 to get my MINI because I wanted a turbo. Anyway, what will fit the MCS in that size? (19 X 7.5 I guess) and what are the lighter wheels. I had RH Pro's on the Evo.
Any help would be great, thanks for your time in advance.
Old 03-25-2007 | 08:51 PM
dxl007's Avatar
dxl007
Subscribe.
Old 03-26-2007 | 02:55 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by dxl007
Hi all,
Welcome to NAM.
I searched in Tirerack.com and didn't see any 19" rims for the MINI.
Only 18" or 20"
Sample search
http://www.tirerack.com/wheels/resul...er+7%2F12%2F06
Note that you have a limited wheel well area that accepts tires up to about 24.7" outer tire diameter and the newest 2007 MINIs come with a different hub bolt size than earlier models which is of fitment concern.
Be sure to check with any wheel vendor that the wheels will fit the newest MINI.
I searched at edgeracing.com and found that many wheels don't come in 19x8.5" and those that do often don't have 4x100 bolt pattern.
See
http://edgeracing.com/wheels/falken_wheel/
19x7.5" in 4x100 from about 25.5 to 26.5 pounds each and up and from $175 to $239 each and up
Or for less weight
http://www.centerlinewheels.com/sub_wheel.php?mw_id=36
19x7.5" 4x100 +42mm offset about 19 pounds several designs many with polished finish
http://www.centerlinewheels.com/whee...ehicle&data=32
426 9578 439 OVERSTOCK!
19.0 x 7.5 silver pearl forged wheel 42mm-offset
Sport Compact Car w/ 4-100mm bolt circle including Honda Civic (4-lug); Acura Integra (4-lug); Mini Cooper; Toyota Car, Scion (4-lug); Mazda Miata, Protege; Saturn (4-lug); VW Cabrio ~ ONLY 1 SET AT THIS PRICE. Order directly from Center Line to get this price.
4-100mm $ 149
Old 03-26-2007 | 05:11 AM
dxl007's Avatar
dxl007
Thanks very much.
Very good replay to my 1st post, and very helpfull. Much better than some other forums.....
I guess I'll have to update my sig to show my car....
Old 03-26-2007 | 06:52 AM
62Lincoln's Avatar
62Lincoln
You might also look around on MINI2 - I faintly recall some European offerings in 19" from a couple of years ago, so it might be possible to find some sources from across the pond. Good luck!
Old 03-26-2007 | 06:55 AM
dxl007's Avatar
dxl007
Thanks.... (-:
Old 03-26-2007 | 08:09 AM
justintime's Avatar
justintime
you ran an 11 stock? snap haha.
Old 03-26-2007 | 08:48 AM
dxl007's Avatar
dxl007
No I didn't say the whole car was stock... Just the Motor, head, and turbo.
I had cams, cam gears, intake, header, down pipe, exhaust, plugs wires, injectors, and a custom tuned AEM. I also ran methonal injection. All good for about 450WHP.
Old 03-26-2007 | 08:49 AM
justintime's Avatar
justintime
ah, nice man.
Old 03-26-2007 | 10:19 AM
Wake|MCS's Avatar
Wake|MCS
Have you considered the more expensive options like HRE, iForged, DPE, etc. Their pricey but the way to go for a set of good looking 19s IMO. If you got the money, why not lol.. if not, there are some people here running 19s, i'm sure they'll chime in. Try motegi I think...
