Proper Wheel Torque... Anyone know ???
Old 05-21-2007, 12:18 AM
minihune's Avatar
minihune
minihune is offline
OVERDRIVE - Racing Champion
Originally Posted by Qksquirt
I looked high and low in the owners manual for my car and couldn't find it, no where, not in the index, not in the area of tire and wheel information. I could be blind but I couldn't find it in the manual.
I went to motoringfile.com and downloaded the 2007 hardtop pdf manual.
Look in "Preparing for a tire change" in Mobility. On page 110 of the manual under "Tightening the lug bolts". It states: Tightening torque: 103.3 lb ft/140Nm.
In the Index on page 142 under "Torque: Lug bolts- page 110".
  #27
Old 05-21-2007, 08:48 AM
rkw's Avatar
rkw
rkw is offline
... and in the 2006 PDF manual (link also at MotoringFile), on page 134 under "Tightening the lug bolts" it says tightening torque 88.5 lb ft/120 Nm. Lug bolts changed from 12mm to 14mm during mid-year 2006. I suspect that this number is for 12mm bolts, and 14mm should use 103 lb ft. like 2007.
  #28
Old 05-21-2007, 09:10 AM
Robin Casady's Avatar
Robin Casady
Robin Casady is offline
I finally found it in the PDF manual (R56 Coupe) by searching on "Nm". It is on page 110 under "Tightening the lug bolts".
"Tighten the lug bolts in a diagonal pattern...
Tightening torque: 103.3 lb ft/140 Nm."
  #29
Old 05-22-2007, 11:34 AM
LondonCalling
LondonCalling is offline
According to the owner's manual, (on my 03MCS) it's 88.5 ft/lbs. Be sure and follow proper tightening sequence. Be careful about applying too much torque or you can warp the rotors. And yes - retorque wheels after driving. I check mine after 100 miles - then 500, then every month or so.
  #30
Old 05-22-2007, 02:15 PM
phydeaux's Avatar
phydeaux
phydeaux is offline
And what is the proper sequence? Simple cross (1-3-2-4 clockwise), or something more intircate? I'm not asking about full 88 lbs before moving on, of course. 88 lbs is the final goal.
  #31
Old 05-22-2007, 04:01 PM
PortMCS's Avatar
PortMCS
PortMCS is offline
^ Yes, i belive thats the pattern youre to follow.
Anyway, im glad someone bumped up this post. It just dawned on me that i replaced my ASA-AR1's with 18"HRE's last week and i did not retorque them. I think im at or about 100 miles.
  #32
Old 05-23-2007, 07:13 AM
phydeaux's Avatar
phydeaux
phydeaux is offline
Fortunately for myself, ~100 will be the day after I put the wheels on in the first place. Go to work, go home, retorque.
Now, I just need to get myself a torque wrench...
  #33
Old 08-16-2007, 06:49 AM
Need's Avatar
Need
Need is offline
How much torque do the bolts lost after 200 miles? When I put my new wheels on, I have the place set the torque to 103 lb ft. They told me to come back after about 80 miles to re-torque. I told them i will do it myself since I bought a torque wrench.
I was going to do it at 100, but forgot so I did it at 200 miles. When I re-torqued them, I found that almost all the bolts were under 90 lb ft. Does it sound normal? I hope I don't have a bad torque wrench. I re-torqued them to 103. I think it took about half a turn on the bolts.
  #34
Old 08-16-2007, 08:19 AM
kenchan's Avatar
kenchan
kenchan is offline
my dealer removed my front right wheel when they did the a/c repair about
2months ago. a few days ago I removed my front wheels to get new
tires wrapped only to find that wheel SUPER KINGKONG OVER TORQUED
LIKE A ****. son of a biotches.
i use 90lbs/ft and re-torque after 4-5miles. then re-torque again when i
get home. by that time the lugs are solid.
07-16-2020 12:54 PM
SosoMINI
11-22-2015 03:17 PM
madmaxxed
09-02-2015 03:32 PM
BowserKart
Tires, Wheels, & Brakes
08-20-2015 01:24 PM
Mini'mon
08-16-2015 04:15 PM
Quick Reply: Proper Wheel Torque... Anyone know ???
