Proper Wheel Torque... Anyone know ???
Old 03-28-2007, 06:19 AM
PortMCS's Avatar
PortMCS
PortMCS is offline
Just ordered my new wheels and tires from TireRack so i need to know what do i torque the new wheels down to? According to TireRack they say to "refer to cars shops manual" which i do not have. I figured someone must know on here.
Thanks in advance !
Vic
Old 03-28-2007, 06:22 AM
mozzarella's Avatar
mozzarella
mozzarella is offline
For the lug bolts believe it's 90 foot lbs
Old 03-28-2007, 06:31 AM
72guy's Avatar
72guy
72guy is offline
89+(-) 7 ft/lbs. I set mine at 92. #'s are per Bentely.
Regards
Old 03-28-2007, 06:51 AM
xbook's Avatar
xbook
xbook is offline
I have heard 88 lbs. That is what i have been using.
Old 03-28-2007, 09:54 AM
sandtoast500's Avatar
sandtoast500
sandtoast500 is offline
80 ft lbs, plus an xtra twist. Tighten them again after a bit of driving, too.
Old 03-28-2007, 12:07 PM
Alan's Avatar
Alan
Alan is offline
120nm or 88.5 ft. lb.
Alan
Old 03-28-2007, 03:30 PM
PortMCS's Avatar
PortMCS
PortMCS is offline
Thanks for the replys guys! But now im confused...
Is it 80, 88 90 or 90 plus? Or does it really matter, as long as i get it at least 88 ft lbs per lugbolt ?
and yes, im aware they need to be re-torqued down after 50-100 mile drive
Old 03-28-2007, 04:14 PM
CmdrVimes's Avatar
CmdrVimes
CmdrVimes is offline
Stuck in Reverse
If you want the specific number you could always look in the manual. It's in there somewhere.
Personally I use ~88-90 ft lbs
Old 03-28-2007, 04:27 PM
am0eba's Avatar
am0eba
am0eba is offline
120 newton/meter is what's in the manual. That converts to 88.5 ft. lb. as stated by Alan.
_Dave_
Last edited by am0eba; 03-28-2007 at 04:28 PM. Reason: fixed english units - sort of
Old 03-28-2007, 07:30 PM
minimarks's Avatar
minimarks
minimarks is offline
I was told 85 foot pounds...
Old 03-28-2007, 07:41 PM
MINI-IZED's Avatar
MINI-IZED
MINI-IZED is offline
From the Bentley service manual: "Road wheel to hub 120 +- 10 Nm (89 +- 7 ft-lb) So anywhere from 82 to 96 ft-lbs should be good. I personly like 90 ft-lb because it is a easy round number that is easy to remember.
Old 03-29-2007, 06:14 AM
PortMCS's Avatar
PortMCS
PortMCS is offline
Thanks everyone! Im gonna go 90 ft-lb's then. Cant wait to get these suckers on the car!
Old 03-29-2007, 06:28 AM
rubyred3's Avatar
rubyred3
rubyred3 is offline
don't forget also, with new wheels, it is very important to retorque the lugs after ~25-30 miles of driving, as the aluminum compresses slightly, loosening them up. 90 ft-lbs is my recommendation. You only have to do this the first time you torque the lugs down on new wheels though, you don't ALWAYS have to retorque after 25-30 miles, but with new wheels, its a good idea.
Old 03-29-2007, 08:29 AM
PortMCS's Avatar
PortMCS
PortMCS is offline
^ Yes ive always done that whenever i purchase new wheels. Im figuring in a day or two they will need to be re-tortured.
Old 03-29-2007, 12:21 PM
kalbone's Avatar
kalbone
kalbone is offline
i set mine to 90ftlbs
Old 03-29-2007, 06:40 PM
Brakefade's Avatar
Brakefade
Brakefade is offline
I don't even own a MINI yet, but I'm already reading through the manual. Anyways, it says 140 Nm or 103.3 ft/lbs. Be safe.
http://www.motoringfile.com/index.php?s=manual
Old 03-29-2007, 06:52 PM
Bullfrog's Avatar
Bullfrog
Bullfrog is offline
So, if I understand this correctly, 88 is correct for the R50/R53 but the new bolts on the R56 should be 103?
Old 03-30-2007, 02:37 PM
Crashton's Avatar
Crashton
Crashton is offline
That doesn't surprise me. It is a different sized lug bolt. Larger I believe.
Old 03-30-2007, 02:42 PM
Crashton's Avatar
Crashton
Crashton is offline
Please explain this to me. I can't understand how this makes sense. 80 ft pounds & an xtra twist????? If you have a torque wrench, why not set it at the proper value & be done with it? Re-torquing is a good idea.
Old 03-30-2007, 03:11 PM
sandtoast500
because I only have a torque wrench that goes to 80 ft lbs.
So I just give it an extra twist past the click, then do it again after a few days drive.
Old 03-30-2007, 03:14 PM
Eric_Rowland's Avatar
Eric_Rowland
Eric_Rowland is offline
Ah, ingenuity at it's finest.
Old 03-30-2007, 04:40 PM
chows4us's Avatar
chows4us
chows4us is offline
Now that is an original thought
Old 03-30-2007, 05:43 PM
Crashton's Avatar
Crashton
Crashton is offline
Yes, now I understand. If you are a strong strapping young man just a bit more may be more that you think. Probably not a problem for an old guy like me. Hey but if it works for you it's OK with me.
Old 05-18-2007, 03:22 PM
Robin Casady's Avatar
Robin Casady
Robin Casady is offline
This is for an R56, right? What page in the manual did you find that?
Old 05-20-2007, 11:56 PM
Qksquirt's Avatar
Qksquirt
Qksquirt is offline
I looked high and low in the owners manual for my car and couldn't find it, no where, not in the index, not in the area of tire and wheel information. I could be blind but I couldn't find it in the manual.
Quick Reply: Proper Wheel Torque... Anyone know ???
