15 holies/ tire size?
the stock tire that comes on the wheel is 175/65/15. the problem with that is the selection of tires in that size sucks!i am a fairly aggressive driver and i guess a wider tire would be in my best interest, right?something like 195/65/15 or 205/65/15? would these sizes work or is that the wrong choice of tire for my wheels?thanks
Check out this tire size calculator, it'll let you see the difference in dimensions between stock and any tire size you're considering.
http://www.1010tires.com/TireSizeCalculator.asp
Tirerack.com has in UHP All season
Bridgestone Potenza RE960AS $73 each 400 tread AA traction H speed rated
195/60-15 seems even better a size
or
Dunlop SP Sport 5000 $64 each 340 tread A traction H speed rated
Kumho Ecsta ASX $48 each 420 tread A traction V speed rated
Better would be 205/55-15 and it allows for better selection of tires that fit.
205mm wide tires are not too wide for stock holey rims.
On the street I have several sets of holeys and 205/50-15 tires that work just fine- side wall flex is OK.
Kimolaoha
12-05-2020 09:32 PM
col127
08-21-2015 02:11 PM
