Need cheap and light 15" that fit Works Brakes
I want some cheap and lightweight 15" wheels that will work with JCW Brakes and some racing tires to use for autocrossing. There are some old posts that show 15 inchers over JCW Brakes. Are any still available? I'd prefer to have them in white, but it doesn't really matter that much.
Any ideas?
Rawhyde
Any ideas?
Rawhyde
JCW 15's - call me to order
OZ Ultraleggera
Motegi Tracklite
Kosei K1 TS
Those come to mind as light 15's that clear JCW's with NO spacer.
Alex
Motegi Tracklite
Kosei K1 TS
Alex
Thanks! The Kosei K1 TS link doesn't work. How about some autocross tires? Not for street use at all, just install them at the track....
Rawhyde
Rawhyde
OZ Ultraleggera
Motegi Tracklite
Kosei K1 TS
Alex
Motegi Tracklite
Kosei K1 TS
Alex
http://www.tirerack.com/wheels/Wheel...re+7%2F12%2F06
15x7" +38mm offset $149 each 12.6 pounds Light Grey, Orange or silver painted finish
Gravity Cast/ Shot peened construction
For track or autocross use can fit-
205/50-15 small outer tire diameter good for autocross 22.8"
225/50-15
225/45-15 small outer tire diameter 22.8"
Dedicated autocross tires-
Check out
kumho V710 in 205/50-15 or 225/50-15
Hoosier A6 in 205/50-15 or 225/45-15
For slightly longer tread wear/durability
Avon Tech Ra in 205/50-15 or 225/45-15
I think I remember reading something about Team Dynamics Pro Race 1 wheels having good brake clearance. I cannot back this up, however. Ignorance aside, they are 15x7" 14.1lb $133 12-spoke cast wheel. They also come in silver, anthracite and black.
Will 07 MC 15" wheels fit a 07 MCS?
If the 07 MC 15" wheels fit JCW brakes will they fit on an 07 MCS? Alex at Tire Rack advised me to look up 15" wheels for my 07 MCS by plugging in a JCW R53 with a built date when the switch was made to the larger bolts. Therefore I would assume that 15" 07 MC wheels will fit an 07 MCS? But then again this could be a bit like the witch scene in Monty Python's Search for the Holy Grail. You know - a duck floats and wood floats so therefore if she weighs as much as a duck she must be a witch .....
Thanks,
Mark
Thanks,
Mark
Oops, my mistake. I was under the impression that all of the R56s had the JCW brakes. Maybe it's just the "S" that has them. The rotors on the R56 Coopers look like the same parts, though.
I was tentatively told that the Motegis should fit, but this is still unsubstantiated info based on 06 JCW fitment. I would love to know for sure, as they would make for a killer track setup.
When I plug in 2007 MCS with JCW kit I only get 17" wheels or larger.
For 2007 MCS tirerack has Motegi's in
Motegi Racing DV5 17x7 for $153 to 194 (chrome plated) each
Motegi Track Traklite in 16x6.5 ($306), 16x7 ($315), 17x7 ($280)
Motegi Track Touge 18x7.5 $225 to $270 (chrome plated) each
When I plug in 2007 MCS at tirerack.com I don't get any 15" wheel options so I don't think it will fit or at least tirerack's check on fitment doesn't suggest that it will fit.
For vehicle select: Mini, 2006, Cooper S John Cooper Works, built after May 2006. Click on Shop for a Winter Tire & Wheel Package. Select 15" packages.
You should end up at this page:
http://www.tirerack.com/snow/WinterT...&performance=W
Now click on the link "Don't need tires? Skip to wheels".
The results list these 15x7 wheels (each has a variety of finishes/colors):
Kosei K1 TS
OZ Chrono HT
OZ Ultraleggera
Motegi Traklite
Motegi Traklite 2.0
Sorry to stay OT, but will these wheels then also fit a 2007 R56 MCS?
I had read the brakes are the same size as the JCW but was not sure.
I need to buy track wheels and the options for tires (Hoosier, Nitto, Toyo...) are so much better for the 15" size wheel (eg. 225/45/15).
See
Kosei K1 TS
OZ Chrono HT
OZ Ultraleggera
Motegi Traklite
Motegi Traklite 2.0
07-16-2020 12:54 PM
Wohnson89
06-10-2020 04:53 AM
08-07-2015 05:55 AM
