Mini Mania: Voted Most Popular Products
The Results Are In ...and we present you with the winners. It's voting week, so we thought it might be fun to talk about which products are the most popular.
This week's Mini Mania election is all about dreaming. Forget practicality. When it comes to your Mini, you need to dream big! Haven't you always imagined finally doing that VTEC conversion? What about simply upgrading your stock motor to something with more of a punch? Is your exhaust system on death's door? Now is the time to upgrade. Wheels, tires, interior gadgets and gizmos, keep dreaming but don't stop there! At Mini Mania, we make dreams into realities every day.
Voted Number 1
Mini Pick Up Body Shell Kit Fiberglass.
This Fiberglass Mini Pickup body shell is sectioned and the pickup components are added at point of manufacture making the finished product a one piece shell. This kit is supplied with doors, bonnet, tailgate upper & lower dash rails and have the option of inner wings. These body shells are supplied...
Voted Number 2
Hydrolastic Wet To Dry Suspension Conversion Kit Mini & Mini.
The stock hydrolastic (wet) suspension as often found on the early Minis has become almost impossible to maintain. The most logical solution is to convert or upgrade the system to the stock 'dry' suspension. This upgrade kit includes KYB shocks (2 ea- 442001 for the front & 2 ea 442002 for the r...
Voted Number 3
"s" Disc Brake Conversion Drum To Disc Upgrade Kit.
No matter how well your Austin or Morris Mini Cooper handles, you still have to stop sometime, and if the car in front of you has ABS you'd better be able to stop your Mini Cooper right now! At one time the only way to get the highly desirable Mini Cooper S disc brakes was to acquire a used set and ...
Voted Number 4
Rear Coil Over Subframe New! Will Fit Any Classic Mini/vtec.
This is the ultimate rear suspension for the Classic Mini. It simply replaces the existing stock Mini frame without any cutting. It includes an anti-sway bar, camber and toe adjustment, and vehicle height adjustment. Rear Coil-over subframe includes everything in above photo. this kit uses stock ...
Voted Number 5
Blue Coil Spring Upgrade With Adjustable Hi/lo Type Suspensn.
The Mini Cooper has earned much of it's reputation because if it superb handling and performance. But many of us would not only like to have great handling but also want it to be comfortable to drive as an everyday street car. The stock Mini Cooper suspension if most often politely called stiff. ...
Voted Number 6
Vtec Conversion Package For Mtk Upgrade.
This Package includes: MTK Kit, K Coil-Over Shock Kit, K Aluminum Radiator Kit, and a Poly Mount Kit....
Voted Number 7
Spi Fuel Injection To Hif Su Rebuilt Carb Conversion.
In the history of the Mini the drive to keep the product alive and marketable meant the factory decided to modernize the fuel system of the Mini from Carb to Fuel Injection. Thus in 1991 the first FI was installed on the Mini. Know as Single Point Injected or SPi for short, the system also incorpora...
Voted Number 8
1275 High Performance Mini Cooper Engines Powerunits.
--->With an estimated 100 horsepower on tap from this engine this great package is ready to install and will absolutely thrill you. The rebored 1275cc motor includes high compression (9.75:1) performance pistons, a Lomgman cylinder head and a fast road camshaft (276 degrees duration). This set up ...
Voted Number 9
165/70/10 A032r Yokohama Aqua Tusk Tire For Mini & Cooper.
Yokohama has upped the ante in performance tires for the Mini! The Yokohama Advan 032R has been a popular tire for Autocrossers and Vintage Racers alike in 13" size; now it's available in 10" for the Mini guys! It has an extremely aggressive tread pattern, and a very soft rubber compound. Size is...
Voted Number 10
Dgv Weber Carb Kit Includes Manifold Carb And Air Cleaner.
Tired of fiddling with SUs? The Weber 32/36 downdraft carb makes an excellent upgrade! This progressive two-barrel carburettor gives you the best of both worlds-power and economy. While cruising, only the 32mm barrel is operating, when you open the throttle the 36mm secondary kicks in! It comes jett...
1971 Austin Mini 1000
1971 Austin Mini Cooper Right Hand Drive This is a 1971 Austin Mini 1000 in super condition and very clean. This car gets over 42.9 Miles Per Gallon. Virtually everything has been done to this Mini ...
Price: $9,850.00
details
1978 Leyland Clubman Estate
Listing my project Clubman estate for sale. the car was a complete driver with the 1098cc 4 speed but I sold the engine in the middle of the restoration. As I grinded away I found more and more rust,...
Price: $1,500.00
details
1972 Mini Cooper
1972 RHD Sedan 1275cc 4 Speed Manual Transmission I am a MINI/Mini enthusiast and have driven this beauty as my daily driver for over a year.I have addressed all mechanical issues that needed to ...
Price: $11,500.00
details
08-07-2015 05:55 AM
08-05-2015 02:11 PM
