Adjustable Sway Bar
Adjustable Sway Bar
Now available for the 2007+ MINI Cooper S Turbo as well as all MINI Models! Increase the handling performance of your Mini by reducing sway and body roll.
Our 22mm-sway bar will balance your MINI's chassis by eliminating the understeer inherent in front wheel drive cars. The sway bar ends features 3 mounting positions for fine-tuning. Rate increase over stock, Hole position 1: +228%, Hole position 2: +297% Hole position 3: +384%
Adjustability
The Madness rear adjustable swaybar features 3 hole adjustment to fine tune the MINI's handling for street or competition use, no need for a smaller bar for street use. Simply use the adjustment points to tune your swaybar for the handling you desire.NOTE: Swaybars do not increase ride stiffness or harshness.
Construction
The Madness bar features one piece forged construction, powdercoated for longevity and built to last the life of the car .Forged bar ends offer stronger and more direct power transfer of the swar bar energy to the wheels. Other manufactures use welded bar ends that while less costly to produce provide a point of failure over the life of the bar. Forged bar ends maintain a one piece design and maintain the steels grain structure and integrity. Notice how the factory bar uses the forging method for the same reasons. When purchasing a swaybar know it's construction method.
Kit comes complete with instructions, sway bar and polyurethane bushings. Shipping costs may be higher than estimated due to box dimensions and destination. This sway bar fits all model of MINI Cooper
Call us on 971-223-3996 or order on our web page at madnessmotorworks.com.
Adjustability
Construction
atlantaorange
09-16-2015 01:43 PM
