:: ECS Tuning :: Euro Wood Dash Kit | H&R Springs | KW Coilovers !!
MINI R50 R52 R53 Wood Dash Kit 7/2004+
This wood dash pattern for the three piece dash adds a little classic Mini tradition to your MINI. Dash is in plastic with high gloss burl wood pattern.
This addition is easy to install and matches other wood accessories. Snaps right into dash once old section is removed.
This kit comes with left main section ( driver ) , center section, and right main section ( passenger ) to complete the 3 piece wood dash look. No airbags covers to worry about.
Old school class & elegance
Fits: Gen 1
R50 MINI Cooper (7/2004- 2006)
R53 MINI Cooper S / JCW (7/2004- 2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE for MINI Wood Dash kit
R60/R61 Countryman & Paceman Powerflex Bushings
Sharpened handling. Increased agility. Tactile responsiveness. A feeling of being one with car and road. Replacing stock bushings with Powerflex polyurethane components will deliver all that and more.
ECS is proud to present the Powerflex brand of performance bushings. Powerflex is a world-renowned name in high-performance products, and they manufacture an array of quality suspension and chassis components.
From subframe mounts to control arm and sway bar bushings and more, nothing overpowers the Powerflex catalog and their reputation for durability and quality.
Pow Pow Powerflex!
Fits:
R60 MINI Countryman /S/SX/JCW (2011+)
R61 MINI Paceman /S/SX/JCW (2013+)
Click HERE for the Powerflex Bushing kit
R52/R53 Supercharged MINI Mishimoto Radiator Hose Kits
The MINI R52/R53 relies heavily on adequate engine cooling to make reliable power. Any leaking, bending, or warping of the hoses that hold cooling fluid will result in a considerable loss of performance & driveability.
Mishimoto now offers a full Silicone Coolant Hose Kit for the MINI, drastically improving durability over the factory hose arrangement, while eliminating flow restrictions.
Molded to exact OEM specifications, the improved design better withstands heat & pressure, resisting swelling and electro-chemical degradation for a longer service life.
Heat Check
Both left (driver) and right (passenger) harnesses are available.
Fits:
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for Mishimoto Radiator Hose Kits .
R56 Cooper ( NON S ) H&R Sport Springs
The most popular spring in H&R's line-up, Sport Springs will lower your MINI an average 1.4" in front and 1.4" in the rear for a lower center of gravity, improved handling, and a more aggressive appearance.
Sport springs are an excellent choice for street and occasional track use, featuring a spring rate that is firmer than the OE Sport spring but still comfortable enough for daily use.
Made In Germany
Fits:
R56 MINI Cooper Base (2007-2013)
Click HERE for MINI H&R Sport Springs .
R50 Cooper H&R Sport Springs
The most popular spring in H&R's line-up, Sport Springs will lower your MINI an average of 1.4 inches for a lower center of gravity, improved handling, and a more aggressive appearance.
Lowering : 1.4 Front / 1.4 Rear
A Tasteful Upgrade
Fits:
R50 MINI Cooper (3/2002 -2006)
Click HERE for MINI R50 H&R Sport Springs.
R56 S/JCW KW V1 Coilover Kit
KW V1 Series Coilovers have been engineered with a damping setting that perfectly suits the MINI R56, while allowing the driver the flexibility to choose a variety of ride heights.
KW "inox-line" coilovers feature stainless steel technology that is superior to galvanizing, better resisting corrosion while maintaining smooth operation over the long term.
V1 Series coilovers also utilize trapezoidal threading to facilitate height-adjustment and increase load tolerance.
An average lowering of 1.2 - 2.2 inches can be expected at both the front and rear.
Step it Up
Fits:
R56 MINI Cooper S / JCW (2007+)
Click HERE for the KW V1
08-12-2015 01:24 PM
08-10-2015 02:03 PM
08-07-2015 09:51 AM
08-07-2015 08:10 AM
