WMW Turbo Wraps ready to ship.
Way Motor Works has our famous WMW Turbo Wrap Heat Shields in stock.
This is different from all the other heat shields you see out there as it is a special made for us. This wraps the turbo housing with silica ceramic to hold the heat in the exhaust and keep it flowing. This wrap is used under the stock metal heat shield so you maintain the stock look and the functionality of the OEM heat shield.
Helps reduce under hood temp and warping of the hood scoop.
You also see we now do them in black for a cleaner look.
In Stock and Ready to order
http://www.waymotorworks.com/wmw-turbo-heat-shield.html
LSX74 (08-10-2017)
