FS:: :: ECS Tuning :: Ziza LED Options : Clubman / Coupe / Roadster
ECS Tuning
Ziza LED lighting kits
You won't believe the difference an LED lighting package makes in your car until you see it with your own eyes. LED illumination is a far brighter and friendlier light, crisp and clean, especially when compared to the dingy yellow glow from conventional filament style bulbs.
Now you can do a complete LED conversion using our R55 MINI LED Interior Lighting Kit. It contains all the LEDs needed for a total lighting upgrade. No need for guesswork or complicated ordering of individual bulbs.
[b]
Click below for you model.
Click HERE For R55 MINI Clubman 2011+ Options
Click HERE For R58 MINI Coupe' / R59 MINI Roadster Options
[b]
bump
Hey I have a question.. I purchased a LED Headlight conversion kit. The kit is plug and play and does not require any special harnesses or capacitors. Problem: when you first start the MINI the LED's flash like a strobe light for about 10 seconds and then stop. I contacted the supplier and they said there is nothing to bypass the initial flashes due to the complexity of the onboard computer testing the lights.. Is this true or did I just get catfishes?
R56 Mini S-2011 Halogen converted to LED
Hello Jake Lee, we dont have any halogen conversions to led bulbs, as they tend to blind people if they are not set in a factory Xenon projector headlight or aftermarket projector housing.
In certain connections on the outside of your MINI they will strobe ( only like five flashes) at start up only as its the LKM and check bulb out system. Its normal with the canbus version in our position lights.
Yes,
Halogen projector conversions : You get and LED omega like the gen 3 MINIs. Plug and play, except you have to tap into the bumper position light or any 12v power on for that. It comes in the directions in the box. The headlight washer covers are dummy covers. Then you get the bi-halogen or you convert to led and brighter halogen bulbs or H9 led ( we dont sell those ). Includes H9 Projector bulbs, there is a flap for the high and low beam.
https://www.ecstuning.com/Search/SiteSearch/ES2862390/
01-22-2016 10:30 AM
12-15-2014 12:47 PM
