Mini Cooper 2001-2006: Suspension Diagnostic Guide
What does that bright orange light mean? What is that sound?
By Piyush Kayastha - June 29, 2016
This article applies to the Mini Cooper (2001-2006).
Your Mini is known for its adept handling and sporty ride, so when those qualities begin to dwindle, there's an issue. Fortunately, these cars are pretty straightforward to tinker with and diagnose any issues. Suspension issues come with a wide range of descriptors, from clunking, banging, harsh, floaty, and many more. If your Mini doesn't feel right, we can remedy it. Let's break it down into the common suspension trouble areas, what the problem usually sounds like, and how to fix it.
Materials Needed
  • WD-40
  • Flashlight
  • Rag
Step 1 – Check your shock absorbers
They might be blown.
Your shock absorbers help control the up and down motions of your springs, and the rate of roll that happens when you throw the car into a corner. Shocks are a wear and tear item, and when they wear out, your Mini will feel excessively bouncy or floaty over bumps. Shocks and struts are easy to check. Jack up your Mini, remove the wheels, and visually inspect the shocks; when they wear out, they tend to blow their seals and leak shock fluid. If your shocks are wet and covered in oil, it's time to replace them. If even that easy test is too much effort, we can further simplify: with your Mini parked on level ground, push down on the front and rear of the car and watch to see how long it takes for the car to stop bouncing. If it's one quick jounce and then back to normal, the suspension is healthy. However, if you jounce the car and it bounces up and down for a few seconds, your shocks are dead and require replacement.
(Related Article: Shock Absorber Reviews and How to Install - NorthAmericanMotoring.com)
power steering suspension sway bar shock strut noise leak sound issue problem
Figure 1. Inspect your front struts and rear shocks.
If your shocks are okay, maybe it's the sway bars.
Step 2 – Inspect your sway bars
Something might be loose.
Your Mini uses anti-roll bars (commonly called sway bars) to reduce the amount of roll experienced by the front and rear suspensions. The front bar connects the front struts together to reduce flex and lean in the corners, while the rear bar is connected to the lower control arms to accomplish the same means. Since these bars are meant to flex and move with the suspension, it's not surprising that they can develop noises with time. The most common sway bar noises come from loose mounting hardware, or damaged sway bar end links (those are the bits that attach the bar to the suspension), and commonly manifests in clunking, banging or even a sharp snapping sound. If your Mini is making a lot of noise on uneven pavement, or over bumps, it's likely one of the sway bars.
Figure 2. The rear sway bar is the usual culprit.
Pro Tip
Drive with your windows down to determine where the noise is coming from, whether it's happening on one side or it's a front or rear suspension issue.
Maybe it's not a noise that's a problem?
Step 3 – Check your dashboard
If your dash is covered in error lights, the problem might be electrical.
A common issue with the Mini is an electrical one. Before you queue up your English car electrical jokes, a basic check of the dash can point right to your problem. Even if it is your ABS, DSC, TPMS or Brake light that is on, or if your speedometer has been temperamental, the fix is a cinch. These Minis seem to commonly lunch through their "Vehicle Speed Sensors (VSS)" or wheel speed sensors, and that sensor, which plugs into the back of the front wheel hubs tends to get damaged and throw all of the aforementioned systems out of wack. For about $100, and an hour of time, all of these woes can disappear.
Figure 3. Replacing your VSS is an easy fix.
Perhaps the issue is electrical, but the problem lays elsewhere.
Step 4 – Is your steering acting up?
Mini has a recall on their power steering pumps.
Your Mini uses electro-hydraulic power steering, which means that it utilizes both a hydraulic pump and fluid, combined with electrical assist for smooth low-speed operation. Early Coopers had issues with their power steering pumps, meaning that periodically the car would lose its power steering, making the steering very heavy and difficult to use. This issue is usually paired with a large red warning sign on the dash. Mini issued a revised pump for late-2005 build Coopers. If you suspect a power steering issue, write down your Mini's VIN (vehicle identification number) and call your local dealer. If your VIN is within the affected range, they should replace the pump free of charge.
Figure 4. Power steering pump.
Related Discussions
