Mini Cooper 2014-Present: Spoiler Modifications and How to Install a Roof Spoiler
In this article, we'll explain what you can do to give your MINI Cooper hatchback a little more aerodynamic efficiency on the track. You'll also find our DIY guide on how to install a JCW F56 roof spoiler.
June 24, 2016
Contributors: amalgamo
This article applies to the MINI Cooper (2014-present).
As you might know, adding a roof spoiler to your MINI Cooper enhances its aesthetic appeal as well as performance, giving it more style, better handling, and even an increase in fuel economy. Whether or not your new F56 rolled out with a spoiler already installed, there are a few modifications you should browse. Continue reading to learn more about spoilers and which one is best for your MINI.
When it comes to any car, especially taller and boxier hatchbacks, aerodynamics plays a huge role. Since a MINI Cooper has a large front faced surface area, the amount of drag and turbulence on the car is relatively high compared with coupes and sedans. However, there are options that can make your MINI more aerodynamically efficient.
As you're driving, the force that keeps your car grounded is its weight, but at higher speeds, the car will begin to experience some lift and the wheels may begin to lose traction. By installing a rear roof spoiler, front lip spoiler, rear diffuser, or side skirts, you can increase the downward force acting on the car, which in turn reduces drag and enhances traction and stability. Here are some F56 spoiler options for you to choose from:
Cooper S Standard Roof Spoiler
JCW Rear Roof Spoiler
3DDesign JCW Roof Spoiler Extension
Price
$250+
$350-2,500
$1,384
DIY Level
Easy
Easy
Easy
Material
ABS Plastic
ABS Plastic
Carbon Fiber Reinforced Polymer (CFRP)
Part Number
51627375856
51627375850
3110-25611
Best Quality: 3DDesign JCW Roof Spoiler Extension
Best Value: JCW Rear Roof Spoiler
Price: $250+
DIY Level: Easy
Material: ABS Plastic
Part Number: 51627375856
The Cooper S rear roof spoiler is your standard, inexpensive option whether you're building your F56 at the dealer or purchasing the spoiler aftermarket. Compared to the JCW roof spoiler, improvements in aerodynamic efficiency are negligible. However, the designs between the two are easily discernible and could be the difference between a sporty or more "regular" look. The standard Cooper S spoiler is composed of ABS plastic, which is a mixture of several compounds and produced at a lower cost. Keep in mind that both the standard and JCW spoilers will have to be painted if purchased aftermarket. Recommended if you're looking for a sleek and subtle design with a semi-sporty flare.
Price: $350-$2,500
DIY Level: Easy
Part Number: 51627375850
The JCW roof spoiler is only one piece of the aero kit produced by John Cooper Works, MINI's personal brand of performance tuning parts. Like the standard Cooper S roof spoiler, the JCW spoiler is composed of ABS plastic, which is not quite as fragile as fiberglass but also not as durable as carbon fiber. Also, the look is flashier than the standard spoiler but not as glaring as a full, over-the-top wing. The price of the spoiler alone is about $350, plus the cost of paint. If you're looking for the whole JCW aero kit package, which includes the air dam, side skirts, and rear diffuser, the cost drastically increases to about $2,500. Recommended along with the entire JCW aero kit for its performance upgrade potential.
Price: $1,384
DIY Level: Easy
Material: Carbon Fiber Reinforced Polymer (CFRP)
Part Number: 3110-25611
3DDesign is a Japan-based company that produces tuning packages for BMW sports cars. A sleek, stylish, and aggressive looking addition to the JCW roof spoiler, the carbon fiber spoiler extensions created by this company are almost necessary if you're looking to heighten your MINI's performance on the track. What may seem like a small, easy-to-install addition to the OEM spoiler adds more downforce to the car and enhances its aerodynamics and handling. Aside from the steep price, the CFRP composite is guaranteed to last longer than the JCW spoiler, and it's also much lighter. Recommended for its high quality material and high strength-to-weight ratio.
How to Install JCW Rear Roof Spoiler
If you're looking to reduce drag and get higher MPG in your MINI Cooper, follow this DIY guide. We'll show you how to remove a standard MINI Cooper S roof spoiler and replace it with a F56 JCW spoiler.
Materials Needed
Plastic trim removal tool
Socket wrench
8mm socket
T20 Torx screwdriver
F56 JCW rear roof spoiler
Step 1 – Remove the lateral cover bolts
Using a plastic trim removal tool, pry off the lateral covers on the top corners of the trunk door. You will see a bolt behind each of the two covers.
Use a socket wrench and 8mm socket to remove the bolts.
Step 2 – Remove the trunk door screws
Open the trunk door and use the trim removal tool to pop off the five rubber covers on the inside of the door, near the hinges.
Then, use a T20 Torx screwdriver to remove the five screws behind each rubber cover.
Figure 6. Remove five T20 Torx screws inside the trunk door.
Step 3 – Remove the standard roof spoiler
Slowly close the trunk door since the standard spoiler has been loosened and is only attached to the frame by plastic mounting clips.
Then, carefully pull off the spoiler so as not to damage the mounting clips.
Figure 7. Locations of roof spoiler mounting clips.
Figure 8. Close-up of roof spoiler plastic mounting clip.
Step 4 – Install the JCW rear roof spoiler
Attach the new spoiler to the trunk door, and make sure you hear it clip into place.
Tighten the two 8mm bolts to a snug fit, and snap on the lateral covers.
Carefully open the trunk door, and tighten the five T20 Torx screws to a snug fit.
Mini Cooper 2014-Present Decal Modifications
Decal Modifications
Add some new flair to your Mini!
This article applies to the Mini Cooper (2014-Present).
Mini Coopers are feisty little vehicles from Britain that ...
Mini Cooper 2014-Present JCW Body Kit Information including part numbers
JCW Body Kit Information (Including Part Numbers)
Improve the looks and performance of your Mini today with a quality aero body kit!
This ...
Mini Cooper 2001 to 2006 How to Remove and Repair Your Headliner
Is your saggy, torn headliner ruining your driving experience?
This article applies to the 1st Gen Mini ...
Mini Cooper 2007-2013 Replacing Antenna
How to Replace Antenna
Break off your roof antenna at the car wash? Click here and we'll help you replace it.
This article applies to the Mini Cooper (2007-2013).
Mini ...
Mini Cooper 2001-2013 Popular Decal Modification Options
Looking for some ways to decorate your Mini? Check out these popular options.
This article applies to the Mini Cooper ...
Mini Cooper 2014-Present Installing Lowering Springs
How to Install Lowering Springs
Sharper handling and sharper looks? Sold!
Lowering springs are one of ...
