Mini Cooper S 2007-2013: Cold Air Intake Reviews and How-to
Installing a cold air intake system in your Mini Cooper S is a great way to improve the sound and performance of the car. It’s a labor intensive project, but certainly something you can do at home. Here’s how.
This article applies to the Mini Cooper S (2007-2013).
The 2nd generation Mini Cooper S has a sweet turbocharged motor and a sporty look, including an aggressive hood scoop, but unlike the 1st generation cars, that scoop is blocked off and just for looks. Many of the aftermarket cold air intake setups you can buy for this car fix this issue. The more expensive units include a funnel that directs air from the scoop back to a newly opened airbox with a free flowing filter. Even without paying for that specially molded funnel, many DIYers have installed a free flowing filter and opened up the scoop for more air flow. When Mini themselves produced the John Cooper Works edition, they used almost the same design for their ram air system. While the reasons for installing one vary, there are three main benefits: (1) It feeds colder air into the intake manifold, (2) it reduces the inherent restrictions that come with the car’s stock systems, and (3) allows more intake as well as turbo noise to escape.
Table of Contents
How to Install Cold Air Intake
Materials Needed
- Ratchet
- Extension
- 10mm socket
- 7mm socket
- Screwdriver
- T27 Torx
- T25 Torx
- 4mm Allen key
Step 1 – Remove the upper air box and filter
For this example we are using the K&N Typhoon cold air intake, which does not include a ram air scoop. Other systems are mostly similar, but there will be some detail differences in the installation. Refer to the instructions that come with the kit, or the website of the manufacturer.
- It is always a good idea when working under the hood to first disconnect the negative (black) battery cable.
- Unplug the mass air sensor electrical connection.
- Unhook the vacuum line from the air box.
- Loosen the hose clamp that secures the intake tube to the mass air sensor.
- Loosen the three screws that secure the upper air box housing to the lower housing; when they’re out, remove the upper air box housing and air filter from the car.
Step 2 – Transfer MAF to new intake
- Remove the two screws that secure the mass air flow (MAF) sensor to the upper air box housing unit.
- Remove the MAF sensor and set aside.
- Install elbow in factory intake pipe.
- Install silicone tube on elbow with hose clamp.
- Check that O-ring is still on MAF.
- Install MAF in new CAI airbox lid.
- Attach cone filter to MAF with hose clamp.
- Secure MAF to silicone tube with hose clamp.
- Install new CAI airbox lid to factory lower airbox.
- Reconnect MAF electrical connection and vacuum line.
Step 3 – Test and tighten
- Reconnect vehicle’s negative battery cable.
- Double check that everything is tight and properly positioned before starting up vehicle.
- Start car and listen for odd sounds like whistles or air leaks.
- Tighten as needed.
- Take the car on a road test and listen for odd noises while driving.
Featured Videos: Intake Install
2nd Gen Mini Cooper S 1.6L AEM Air Intake Installation
2nd Gen Mini Cooper S 1.6L K&N Air Intake Installation
Alta Performance |
K&N Typhoon |
AEM Cold Air Induction |
DDM Works Race Intake |
GruppeM Sports |
Racing Dynamics Carbon Fiber | |
Price |
$275 | $225-270 | $400 | $450 | $550 | $800 |
Filter Durability |
50,000 miles | 100,000 miles | 25,000 miles | 100,000 miles | 100,000 miles | 100,000 miles |
Filter Type |
Foam | Oiled Cone | Dry Cone | Oiled Cone | Oiled Cone | Oiled Cone |
Warranty |
5 years | Million Mile Limited | Limited Lifetime | None | None | None |
Ram Air Scoop |
No | No | Plastic | Aluminum | Plastic | Carbon Fiber |
Performance Claim |
10hp, 10lb-ft | 11.1hp | 14.14hp, 11.3lb-ft | None | Yes | None |
Best Value: DDM Works Race Intake
Alta Performance
Price – $275
Filter Durability – 50,000 miles
Filter Type – Foam
Warranty – 5 years
Ram Air Scoop – No
Performance Claim – 10hp, 10lb-ft
The Alta Performance cold air intake is the only one here that comes with a foam filter element instead of a cone type. It is widely known that the foam element flows more air, but at the expense of not filtering as well, and more intake and turbo noise. If you are looking for the whoosh of the turbo to be much more prominent, this is the system for you. One major downside of this system is that it does away with the lower airbox, and leaves the filter exposed to the hot air of the engine bay. Opening up the hood scoop will allow air to flow to this filter, as it is a bit higher up, right against the hood. The claimed gains in power and torque are quite good, but would likely only apply until the turbo gets hot. Best for buyers looking for a lower priced system with maximum turbo sound.
K&N Typhoon
Price – $225-270
Filter Durability – 100,000 miles before replacement
Filter Type – Oiled Cone
Warranty – Million Mile limited warranty
Ram Air Scoop – No
Performance Claims – 11.1hp
One of the top-notch and most highly recommended among cold air filter systems, the K&N brand is well known among Mini Cooper owners, and for good reason—the company makes good, reliable products. Reviewers consistently rate these air intake systems highly, and cite easy installation as well as improved sound/performance of their vehicle post-installation. The K&N system does not come with a hood scoop, but does attach to the factory lower box, so the filter is shielded from much of the hot air in the engine bay. This is made to be used with the hood scoop opened as well, and the performance gains were tested in that configuration. While there is no scoop with the K&N kit, the design makes it possible to add one of your own creation if you would like. Best for buyers looking for a name brand cold air intake with a reputation for quality.
AEM Cold Air Induction System
Price – $400
Filter Durability – 25,000 miles before replacement
Filter Type – Dry Cone
Warranty – Limited warranty
Ram Air Scoop – Plastic
Performance Claims – 14.14hp, 11.3lb-ft
AEM was one of the first companies to design and make a functional ram air intake for the R56 Mini Cooper S. This cold air intake truly is a cold air system, drawing in air from outside the engine compartment and directing it back to the air box. The plastic ram air scoop will not heat up and affect the air temp like a metal one would either. Best for buyers wanting a low cost true cold air intake with a functional hood scoop.
Price – $450
Warranty – None
Ram Air Scoop – Aluminm
Performance Claims – None
If you are looking for a cold air intake with a working hood scope made entirely of aluminum, with no plastic parts, the DDM works system is for you. This nicely made airbox and hood scoop combo uses a genuine K&N filter element as well, so you know once you install it, it will be good for the life of the car, as long as you wash and oil it occasionally. At $450, it isn't cheap, but it is practically indestructible. They will also sell you just the ram air scoop if you have the Alta, or K&N CAI installed and just need to get the cold air back to them. Best for buyers looking for a durable system, with a real working scoop.
GruppeM Sports
Price – $550
Warranty – None
Performance Claims – Yes
GruppeM does not mess around, and this may be the most well engineered system available. There are no performance gains specified, but horsepower and torque are increased. This system used a real functional scoop, engineered to get the most cold high pressure air from the hood scoop back to the air box. A stainless steel heat shield is added to the factory low air box and a whole new top section much like the K&N intake is bolted to it. They also use a real K&N filter element for long lasting power gains. Best for those who don't mind spending and want the best engineered system available.
Price – $800
Warranty – None
Ram Air Scoop – Carbon Fiber
Easily the most expensive system here, the Racing Dynamics cold air intake has something the others don't, and that is real carbon fiber. Not only is it lighter, and practically indestructible, it is also a great heat insulator. Unfortunately, they offer no dyno sheets or power gain claims, but with a real K&N filter element, functional ram air, and carbon fiber insulation, it surely must be at least as good as the rest of them. Best for buyer who must have carbon fiber and want a cold air intake with real ram air.
Related Discussions:
- CAI for R56 Home Made - NorthAmericanMotoring.com
- Best Cold Air Intake - NorthAmericanMotoring.com
- New Mini Cooper Intake from AEM - NorthAmericanMotoring.com
- Mini Cooper CAI - NorthAmericanMotoring.com
- NM Cold Air Intake or M7 Cold Air Intake - NorthAmericanMotoring.com
